Pcv
Old Oct 5, 2012 | 08:32 AM
nonnieselman's Avatar
That will work.. but my fresh air comes from my Air box..
Mine is setup stock on the Driver side with the hose goin from the Top of the Intake to the Driver side Valve Cover with the PCV check valve in it.
Passenger side valve cover is goin to the air box. Plugged off the port on the Throttle body.
Very simple..
Took the turbo elbow off last night and see i have oil making its way into the turbo.. so now its oil catch can time.
Old Oct 5, 2012 | 09:09 AM
Denali08's Avatar
Very simple..
From where is the oil coming?
Old Oct 5, 2012 | 09:15 AM
crank case getting some blow by and pushing fumes to the airbox from the passenger side valve cover plus the vacuum from the turbo inlet..
Old Oct 7, 2012 | 08:33 PM
TRD_Tundra's Avatar
Can this cause the truck to smoke and make the turbo get hot enough to get the turbo blanket smoking? I just installed a turbo kit and had no Idea that it needs this "PCV" thing.
Old Oct 8, 2012 | 10:58 AM
Yea if its puking oil..
You need somewhere for BlowBy to go.. if you leave it all stock, then your pressureizing the crank case from the port on the top left of the throttle body..
I basically plugged the Throttle body port, and ran that hose to my air box..
Old Oct 8, 2012 | 11:16 AM
Atomic's Avatar
I have a gauge for that
The way you had it set up you would be pulling oil fumes from the case through the turbo...not how I would do it...I just put breathers on both covers and called it a day. Also, my hobbs switch is rather lazy. Its a 3psi switch but sometimes wont click over until 4 or 5...so if yours is the same way you would be momentarily pressurizing the crankcase, so dont be suprised if you end up with a rear main leak...
Old Oct 8, 2012 | 11:22 AM
im putting a catch can on mine today.. i took the airbox off and can see very little oil residue in the turbo housing..not good
lucas287
31
Jan 12, 2021 06:18 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
mhorn0817
Jul 8, 2017 01:54 AM
JordanH
Oct 3, 2015 03:59 PM
jroctpb
Aug 11, 2015 03:52 PM
