paxton question
Old Nov 10, 2006 | 12:49 PM
blackout01's Avatar
Default paxton question
Long time reader, first time posting...be gentle
I have an 01 z71 tahoe 5.3 and have a friend who wants to sell his paxton supercharger to me for $1000. He claims that I do not need a any fuel pump or injector upgrade or a tune. I have always heard that you at least need a tune when going F/I. Any info is greatly appreciated...
Old Nov 10, 2006 | 06:04 PM
03sierraslt's Avatar
You will absolutely need a tune, as far as injectors or fuel pump I stongly suggest both of them however if you are running low boost you could most likely get away with just injectors. I would do all three so you dont have to worry about it...
Old Nov 10, 2006 | 06:05 PM
You dont want to run out of fuel, if you do the motor will go boom...
Old Nov 10, 2006 | 06:23 PM
blackout01's Avatar
How big of injectors would I need? It will running around 8lbs of boost.
Old Nov 10, 2006 | 07:21 PM
If you are running 8lbs then get the 44lb injectors and a upgraded fuel pump. Is this kit intercooled? If not then you might want to look into doing so or at least adding meth.
Old Nov 10, 2006 | 07:35 PM
Injectors- TSP injectors
Fuel Pump-TSP Fuel Pump kit
The injectors have to be the Multec II's (shorties) you can use the standard LS injector however you have to space up the fuel rails 5/8" and solder and splice the injector wiring harness. If you go with the Multec II's they are a direct swap. I cannot say for sure if the link provided above are the Multec II's because it doesnt say however you could always contant a vendor to find out. These are just some examples for you.
Old Nov 10, 2006 | 11:16 PM
blackout01's Avatar
I appreciate the info, looks like im gonna need to dip a little further in the savings...
Old Nov 11, 2006 | 09:07 AM
Ya, if you are going to do it then do it the right way or else you will be dipping way into savings to replace a motor.
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
