Passing Smog
Old Mar 3, 2008 | 10:08 PM
Sleeper Bowtie's Avatar
Default Passing Smog
I have to get my truck smogged .Have any of you guys had any problems passing with the same setup as mine?I'm going on Wednesday and i'm kind of worried.
Old Mar 3, 2008 | 10:16 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
J's01Silverado passed CA smog with a 6.0 and similar mods. Good luck, get it good and hot before you take it in and keep us posted!
Old Mar 4, 2008 | 12:02 AM
Last Call's Avatar
TOTM: January 2007
I dont know how I passed, but I did.
I did what Trever1t did and got it hot before it was tested. Just make sure the SMOG guy keep it out of boost when he puts in on the dyno.
Old Mar 4, 2008 | 12:06 AM
Does a loose converter make it harder to pass since its in a higher RPM?
Old Mar 4, 2008 | 12:16 AM
Last Call's Avatar
TOTM: January 2007
Probably.. but a 2600 or 2800 stall is probably not loose enough to make a big difference. I have a 2800 and it is not much different than stock until I have traction and flash it off idle.
Old Mar 5, 2008 | 09:29 PM
Well i just got home and my truck passed smog at a test only place.Not only did it pass with no problem but the converter seemed to help, the RPMs were at the same 1750rpm at 15mph and 25mph.
Old Mar 5, 2008 | 09:36 PM
BlownChevy's Avatar
blownerator
25 Year Member
AND you got new tires
Old Mar 5, 2008 | 09:41 PM
Sure did Thanks again Brian
Old Mar 5, 2008 | 09:42 PM
BlownChevy's Avatar
blownerator
25 Year Member
Any time bro....I am glad your truck made the grade.
Old Mar 15, 2008 | 11:49 PM
One_Slow4.8's Avatar
did you pay the guy off lol? how did you pass the visual inspection with those magnaflow cats? my cats went out and i might just order those if they work.
