p0172 & p0175 out of the blue???
Old Jan 24, 2009 | 12:29 AM
JOHN1L40's Avatar
Default p0172 & p0175 out of the blue???
My truck has been running flawless for the past year and then I get these codes. I scanned the truck and my LT trims on both banks went from -1.6 to around -10 to -13 at idle. I thought it might be a dirty MAF as I have an STS turbo and i get a little oil in the intake now and then. I cleaned it twice but no help.
My question is how can I tell I tell if my MAF is working correctly? Is these a set voltge or flow rate I should look for?
I get both codes on BANK1 and BANK2 so I am assuming it is not an o2 sensor.
Anything else I can look for?
Old Jan 24, 2009 | 12:35 PM
1BADAZZSS's Avatar
I am in the same situation. Ever since I had the tune reflashed for the 60lb injectors my ses comes on for a day and shuts off. Does that repeatly. Also have problems dieing when come to a stop or trying to find idle. Scanned it and said bank 1 and bank 2 lean. Gonna try replacing front 02's and maf and see if that fixes it.
Old Jan 24, 2009 | 01:40 PM
turbomax's Avatar
i have the same problem also
Old Jan 24, 2009 | 02:21 PM
TG02Z71's Avatar
Colder than normal temps outside? Condensation on your MAF??
Don't know where you live soo....
Old Jan 24, 2009 | 03:48 PM
Midnightrider's Avatar
your o2s are going out those oare the same codes i threw when i ran leaded gas and fried the o2s replace the sensors
Old Jan 25, 2009 | 11:55 PM
JOHN1L40's Avatar
The front o2's on both sides?? Or all 4?
Old Jan 26, 2009 | 12:16 PM
S/C Z71's Avatar
Banned
Just the front two. With the engine idling tap on the MAF with a screwdriver handle. If the engine stumbles then the MAF is bad.
redbird555
Sep 30, 2015 09:28 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
Velocity1
Sep 22, 2015 01:32 PM
kalikid06
Sep 20, 2015 07:46 PM
RONIN LSX
Sep 19, 2015 05:33 PM
