Ordered Turbo, now i need help
Old Feb 4, 2010 | 02:57 PM
THE-HOE's Avatar
Default Ordered Turbo, now i need help
I have a KB racing turbo kit on the way turbo is a Masterpower T76 Q-trim turbo, 27 inch FMIC, and 3 inch down pipe. This is eventually going on a forged 6.0 but for now its going on my 5.3. I have talked to many companies already about what cam I should get but I wanted to see what you guys thought also.
It will be a stock 5.3 that will be almost daily driven. It will be going in a 2001 Tahoe that is 4wd, so it weighs 5600lb. I know alot use the ls6 cam, but i want to try to make a little more power than it does. ( if possible) So what cam, or cam specs should i look for?
Any suggestions are appreciated.
Old Feb 4, 2010 | 03:07 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
pm STOCK48
PATRIC G is the man!!!
Old Feb 4, 2010 | 03:24 PM
lownslo's Avatar
stock4.8 deals in custom grind isky cams and can reccomend one that will fit you just right.
Old Feb 4, 2010 | 03:33 PM
TIM Z's Avatar
11 sec. Truck Mod
Congrats on the kit!
Im putting a 220-224 in my 5.3 now, But am going to add a KB racing kit soon.
Hope this cam works good with boost, i was told it would.
Old Feb 4, 2010 | 03:57 PM
lownslo's Avatar
umm not sure about that cam. what is the lsa because that is a big cam for turbo!
Old Feb 4, 2010 | 04:41 PM
TIM Z's Avatar
11 sec. Truck Mod
I'll have to check. Its not ordered yet so im still good.
Old Feb 4, 2010 | 04:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do some research Tim, things have changed a bit since youve been gone. Welcome back
Old Feb 4, 2010 | 04:59 PM
silver-mod-o's Avatar
Hunt&Fisherator
the duration isnt necessarily the issue... overlap is... and even thats not a big problem unless youre trying to squeeze every single hp out of a setup.
I was recommended a 218/224 .588/.595 113 for my 5.3/70mm setup. I'm sure it would also work very well for a 6L setup too. Cam choice isnt AS critical as a n/a setup.
Old Feb 4, 2010 | 05:10 PM
GMCtrk's Avatar
Ive got a speed inc TU1 for sale....nasty turbo cam. 225/225 113+1
Old Feb 4, 2010 | 06:11 PM
THE-HOE's Avatar
Originally Posted by denali_on_26's
pm STOCK48
Will do, thanks !
