Ongoing 5.3 turbo build
Old Dec 11, 2014 | 05:04 AM
Show-n-go5.3's Avatar
Default Ongoing 5.3 turbo build
Here are some snap shots of my progress on my boosted 5.3. Its taking me for ever to build this and im spending way more money than originally planned. The truck is bagged and lays frame, so ive had to custom build everything to fit. MP T76/68 .96AR turbo, custom grind comp cam, ported and polished 243 heads, comp trunion upgrade, holley high ram 102mm intake, 4" innercooler, dual 340 aeromotive pumps, 96# injectors, -10 fuel line .......
Thats the bulk of it. These are just the mock up pics during the fabrication.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][IMG][/IMG][/IMG]
ill post some more pics later.
Old Dec 12, 2014 | 05:07 AM
Since then ive traded Magnum for a bigger turbo (M477 76/78 1.15AR), Fabbed some coil covers, got a new Holley high ram 102mm intake, 4L80E trans (added shift kit and painted it), and a 5" drive shaft.
[IMG][IMG][IMG][/IMG][/IMG][/IMG] [IMG][IMG][URL=http://s1375.photobucket.com/user/James_D_Easton/media/Facebook/truck%20pics/7E594F00-ADF0-4578-B9AD-EEB77B3FA918_zps6xawwao2.jpg.html][/URL[IMG][/IMG]][/IMG][/IMG]
Old Dec 12, 2014 | 12:55 PM
boostedsl2's Avatar
bad ***.
Do you have pics of your coil over setup? I'm going to fab up my own and am curious to what you used.
I was planning on the following for a setup and building brackets for both ends of the shock.
Front Suspension Stuff:
Qty - 2 - QA1 Shock Bearing Kits COM8T-102PK - $29.97
http://www.summitracing.com/parts/hal-com8t-102pk
Qty - 2 - QA1 Coil Springs 10-650 - $37.97
http://www.summitracing.com/parts/hal-10-650
Qty - 2 - QA1 Proma Star Coil-Over Shocks DS403 - 159.97
http://www.summitracing.com/parts/hal-ds403
Old Dec 12, 2014 | 03:26 PM
My truck is bagged and lays frame. Complete custom rear set up
[IMG][/IMG][IMG][/IMG]
Old Apr 30, 2015 | 04:21 AM
Default update
Here is a little update on the progress.
Size:  225.4 KBName:  40E88C0B-33C2-456A-89B7-998E8DDDE4E9_zpsujjc7bvs.jpg
Size:  195.3 KBName:  00000000-0000-0000-0000-000000000137_zpsu57g6exr.jpg
Size:  220.5 KBName:  00000000-0000-0000-0000-000000000134_zpsax4wlv8j.jpg
Size:  186.4 KBName:  00000000-0000-0000-0000-000000000131_zpsgjqavsuu.jpg
Old Apr 30, 2015 | 06:24 AM
Byrdman11's Avatar
Looking good!
Old Apr 30, 2015 | 11:04 AM
08DenaliT's Avatar
How are you at techno the covers the build looks so amazing
Old May 1, 2015 | 07:41 AM
Techno?
Old May 30, 2015 | 10:21 AM
Default first start up
she's almost on the road finally. I have to get a new map sensor connect the turbo to the air box and paint the hood. Here is a short video of the progress.
Old May 19, 2016 | 04:09 AM
Default update
Last summer the truck ran great after i got the tune sorted out but it was time for a transmission rebuild. The 4L80 that i used had a lot of miles on it and was basicly stock besides the HD2 shift kit. I rebuilt the trans myself using a Jake's Performance level 3 kit. I also had to add a Truecool 40k to keep the trans temps down.
Trans is in and working awesome. I also installed a Alkycontrol metyhanol injection kit so i can increase boost.
Here is a little video from last night before i changed my rear tires.
