old school procharger
Old Oct 25, 2013 | 09:53 PM
cwalker2006's Avatar
Default old school procharger
A guy wants me to install a procharger on his truck for him. The head unit is the old school one I guess. The oil lines feed like a turbo setup. Its not self contained. Would I Just tap the oil pan for the return like normal. Or could I use the block for the oil cooler for inlet/return? I have a spare oil cooler block not being used.
Old Oct 26, 2013 | 12:04 AM
Fast86z's Avatar
I just driled the pan on mine (cast aluminum). I used a vacuum hose next to the drill bit to suck up particles. It worked great, however when I finally pulled the pan there were lots of metal shards stuck in the pickup screen. I would do it again however since it did not seem to cause any oiling problems. Just make sure you change the oil afterwards, and know that there will be metal shaving stuck in he pickup screen.
Old Oct 26, 2013 | 06:01 AM
JRENIGAR's Avatar
Pack the drill flutes with bearing grease to hold the shavings. It worked well when I tapped the pan on my ls car for a vortech install.
Old Oct 26, 2013 | 02:08 PM
Do I need to run a regulator on the feed line?
Old Oct 26, 2013 | 02:11 PM
Choda's Avatar
I also used grease on the bit and tap and it helped big time.
Old Oct 26, 2013 | 03:19 PM
If I use -3an feed line will I need to use a regulator for the oil?
Old Oct 26, 2013 | 04:29 PM
Chevy_King1500's Avatar
I'm not sure how the seals are on those I have a .07 oil restrictor on my turbo because it kept blowing past the seals my truck idles with 50-55 psi
madmann26
Apr 29, 2020 09:17 AM
Vortec350ss
Jan 12, 2016 10:36 PM
Chewy07
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
murderedSS
Sep 27, 2015 10:16 PM
