oil pressure too high???
Old Apr 24, 2010 | 06:56 PM
Badboy464's Avatar
Default oil pressure too high???
I took my rear mount off and front mounted it and now when I get on it it smokes like CRAZY. So I put a nos jet in there at about .050 (3/64) and it helped a little but its still way too bad. When I had it on the rear it didn't smoke at all. I would put a smaller jet in there but I don't want to burn up the turbo. What do you guys think I should do? (I've already spent alot of time in the search section)
Thanks
Old Apr 24, 2010 | 07:02 PM
tarinitup's Avatar
9 Second Truck Club
How high is it and what weight of oil do you run. With 20 w 50 and a -4 feed without a restrictor to turbo it sits at 55psi idle and peggs the guage at WOT. I thought that was normal.
Old Apr 24, 2010 | 07:16 PM
Badboy464's Avatar
oil presure is at around 40 when warm and idleing but thats not the problem problem is when I get on it it leaves a big cloud of smoke behind me. and I know its not the turbo because it didn't do this before I swithched it to the front.
Old Apr 24, 2010 | 07:18 PM
tarinitup's Avatar
9 Second Truck Club
Sounds like it could be tuning related and running rich. What color of smoke is it? I get lots of smoke behind me too but it's usually the tires.
Old Apr 24, 2010 | 07:20 PM
smokeshow's Avatar
Mod with training wheels
Sounds like a diesel
Old Apr 24, 2010 | 07:27 PM
Badboy464's Avatar
It's blue smoke and it only happens when I get on it and the oil pressure increases. I took the one way valve off the sts setup when I switched so I think im gonna put that back on and see what happens.
Old Apr 25, 2010 | 01:06 AM
kbracing96's Avatar
How is you PCV setup? did you keep the valve setup that STS has on the pass side valve cover to the TB?
Old Apr 25, 2010 | 10:35 AM
1989k1500's Avatar
Hows your drain setup?
Old Apr 25, 2010 | 12:07 PM
zeake's Avatar
You might getting oil into the intake from crank case pressure. Are you running more boost than before?
Old Apr 25, 2010 | 06:46 PM
joeyc125's Avatar
11 Second Truck Club
