Oil pressure adaptor fittings.
Old Jun 11, 2007 | 11:19 PM
WJ MARK's Avatar
It worked perfect with the factory gasket.
Old Jun 13, 2007 | 09:26 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by 99RCSB
I would be very intersted. What size is it tapped to?
What size shirt do you want.? with your order.
Rick
Old Jun 13, 2007 | 10:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ill purchase one as soon as we confirm it will work with the STS feed line, Im too lazy to search and find out what size/thread it is
Old Jun 13, 2007 | 10:57 PM
TrickTurbo's Avatar
Truck Sponsor
do you know what wrench you used to tighten the hose end.
you could buy the adaptor and then that will force you to look.
let me know when you can.
Old Jun 14, 2007 | 08:11 AM
TG02Z71's Avatar
Looks good but a 90* fitting would probably be needed for some trucks.
My 4x4 has little to no clearance using the stock tapped piece of junk. The line is unnervingly close to the drive shaft.
Old Jun 14, 2007 | 01:21 PM
alanderson1978's Avatar
The oil line on the STS is an AN-4. I think it comes with an AN-4 to 1/8" NPT 45* fitting.
Old Jun 14, 2007 | 02:04 PM
WJ MARK's Avatar
I used a 90 on mine. Worked sweet! Easy to install and tighten the lines, no clearance issues at all. Mine is also a 4X4
Old Jun 16, 2007 | 06:42 PM
Rick
Your inbox is FULL!!
Thank you
Old Jun 16, 2007 | 08:46 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by alanderson1978
Rick
Thank you
NOT anymore.
simman22
Jan 21, 2017 10:27 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
