Oil pressure adaptor fittings.
Old May 5, 2007 | 01:26 PM
TrickTurbo's Avatar
Truck Sponsor
Default Oil pressure adaptor fittings.
We want to see if there is any interest in having an adaptor built for these NON oil cooler trucks.
Instead of pulling the stock block off drill and tapping, you could just unbolt and rebolt the new flange.
Here are a couple of pics of what it looks like.
Pricing has yet to be spec'd out, range should be arond 20-30 dollars, depending on how many we produce.
Rick
Attached Thumbnails Oil pressure adaptor fittings.-oil_adaptor.jpg   Oil pressure adaptor fittings.-oil_adaptor2.jpg
Old Jun 11, 2007 | 11:06 AM
WJ MARK's Avatar
I used one of these on my truck and worked great! Sure saves you some time with the install.
Old Jun 11, 2007 | 03:41 PM
99RCSB's Avatar
I would be very intersted. What size is it tapped to?
Old Jun 11, 2007 | 05:28 PM
WJ MARK's Avatar
1/8 NPT. I used a 90 1/8 npt to -3 I think, to the turbos oil supply line.
Old Jun 11, 2007 | 06:42 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ill take one.
Old Jun 11, 2007 | 06:56 PM
blowme's Avatar
I hate the STS design on the oil pickup. Do you this this would replace their crap and not leak? I am not sure what size fitting they use but if I can get it all to connect I would like one as well.
Old Jun 11, 2007 | 07:27 PM
TheBiz's Avatar
The only thing I see that would be a problem with that design is the guys with LT headers will have some clearance issues with the huge Autometer pressure unit sticking strait out from the block. I know on my Trans Am ( I know we are talking different cars, but its the same basic block) I have clearance issues with the factory bock-off and the sender pointing up. Just my $.02.
Old Jun 11, 2007 | 08:23 PM
99RCSB's Avatar
Sounds good to me. I'll take one.
Edit: Do you provide a gasket for it or will a GM replacement work?
Old Jun 11, 2007 | 08:36 PM
TrickTurbo's Avatar
Truck Sponsor
we could just get you a 1/8 male x 1/8female 90' fitting or 45'. This would allow you to put the sensor anywhere.
Rick
Old Jun 11, 2007 | 08:46 PM
TrickTurbo's Avatar
Truck Sponsor
Ill take one.
Ok pm me
if you have a pic of the hose end and what size wrench you used to put it on, I can get you a fitting to match up to your set up.
YOu can reuse the GM gasket, its a rubber type easily reuseable.
We have a couple we built sitting on the shelf right now. WE take pay pal. Can ship tommorrow.
Rick
