oil line presure ???
Old Feb 26, 2009 | 05:05 PM
GOT LS1's Avatar
Default oil line presure ???
I got a couple questions about where every one with a turbo set up is getting oil pressure for there turbo and how they are returning it since im doing a custom set up. the set up im going with is some what the same as the high mount trick kit but im using a side mount IC and plumbing my own intake. I'll probably be back asking a few more questions trough out the build so any info, tips, tricks or hints is greatly appreciated and thanks in advance for your help.
Old Feb 26, 2009 | 05:12 PM
Wilde Racing's Avatar
How do I change this text
What year, and is it a truck? Depending on year, and engine size you may or may not have a engine oil cooler. If you dont, it is a simpile mater of drilling and tapping the oil cooler cap above the filter.
Old Feb 26, 2009 | 06:21 PM
GOT LS1's Avatar
its a 2006 silverado 2wd and im not sure if it has an oil cooler on it.
Old Feb 26, 2009 | 06:42 PM
charcold-bowtie's Avatar
Mine didnt have a oil cooler
oil pressure from above the filter, just drill it and tap, notice the fitting already screwed in.
the return from the pass fenderwell.
Old Feb 26, 2009 | 06:52 PM
GOT LS1's Avatar
did u have your trans out of the truck when you drilled the hole for the oil pressure?
Old Feb 26, 2009 | 06:58 PM
ugh no. For the pressure side, first pic, that little piece comes off, see the two bolt holes.
On the other side, pass fenderwell, just get a drill, I raised the front of the truck high, so it will push shaving out and not let them get into the oil pan. I left the pan on my truck tho.
Old Feb 26, 2009 | 07:13 PM
GOT LS1's Avatar
cool, thats exactly what i needed. thanks for your help. its a custom build for the most part so its not like i got installation instructions to go by and this is my first turbo install, thankfully i got help from a friend. what size turbo you runnin with the 4.8?
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
jroctpb
Aug 11, 2015 03:52 PM
Mzay
Jul 6, 2015 11:03 PM
