oil feed line?
Old Sep 9, 2013 | 07:15 PM
darnie's Avatar
Default oil feed line?
i ordered a oil line kit from tricks, and it cam with a -10an drain line and a -3an feed line. the trubos a 76mm is the -3an going to be ok?
Old Sep 9, 2013 | 08:11 PM
Im using a -3 with no restrictor and it works just fine
Old Sep 9, 2013 | 08:15 PM
darnie's Avatar
ok cool, how do you have it going into the pan? do you have a adaptor or does the 1/8 work?
Old Sep 9, 2013 | 08:32 PM
Ferocity02's Avatar
-3an here too with my Turbonetrics 7668. I feel like 3an is fine for T4 turbo's, especially the smaller ones like Turbonetics and Magnum. Maybe a BW T4 would be better with 4an?
Old Sep 9, 2013 | 10:05 PM
darnie's Avatar
ok cool, ill just give it a shot and see what happens. im going to try and do that and just tap the pan for the drain line. how many quarts should i use to make sure the pans flushed out all the way? ill also use a pen magnate to help pull any shavings out
Old Sep 9, 2013 | 11:18 PM
Atomic's Avatar
I have a gauge for that
-3 will be fine....hell a run -6 and its fine too
Old Sep 10, 2013 | 01:28 AM
darnie's Avatar
ok cool ill hook up the feed. and whats the best location to just tap the oil pan without dropping it?
Old Sep 10, 2013 | 03:09 AM
idahoblkss's Avatar
A magnetic pen ain't going to help considering you probably have a aluminum pan. Just tap it below the crank pulley just make sure you got room for it where you tap it.
Old Sep 10, 2013 | 07:20 AM
Atomic's Avatar
I tapped mine forward of the starter behind the motor mount.
Old Sep 10, 2013 | 09:28 AM
Ferocity02's Avatar
I tapped mine right above the oil level sensor about as high as I could get it. I dropped the pan to do it, it's not too much extra work on a 2WD.
