oil feed line?
Old Nov 6, 2012 | 08:22 AM
murdock.dean's Avatar
Default oil feed line?
Where are people taping in for their oil feed line and are you using a inline restrictor to keep oil pressure down.
Old Nov 6, 2012 | 08:31 AM
holley2346's Avatar
My kit came with a plate the bolts to the side of where the oil filter is on the engine... the plate was pre threaded for a fitting to connect the line to.
Old Nov 6, 2012 | 08:36 AM
nonnieselman's Avatar
If you look above the oil filter, theres a oil port boss. its got 2 bolts holding it on.
Take that off and drill/tap it for 1/8" NPT and put a fitting in there to adapt it to -4AN. Vola theres your oil feed line.
No restrictor here.
Old Nov 6, 2012 | 10:20 AM
chevrolet all the way's Avatar
No restrictor here. nor do i recomend one. tried it and you could here the turbo scream from a lack of oil. one rebuild later i had no restrictor.
Old Nov 6, 2012 | 10:27 AM
Also using the oil boss and -3an with no restrictor
Old Nov 6, 2012 | 11:07 AM
Ferocity02's Avatar
Ask the turbo manufacturer about a restrictor. I was told to use a .0625 one, my oil pressure is at 80 psi above 4000 rpm.
Old Nov 6, 2012 | 11:30 AM
Alpinestar's Avatar
I'm running a restrictor but forgot exactly which size nitrous jets do the trick...
Old Nov 6, 2012 | 11:50 AM
03regcab sierra's Avatar
I have mine tapped like mentioned above no restrictor -4an feed line. I also have a plate that u can bolt between with a fitting on it. I can upload a pic for u if interested. I do have it for sale
Old Nov 6, 2012 | 01:47 PM
custom 68's Avatar
Mine is a little different since it is in a swap vehicle. I used the oil pressure gage port on top rear of the engine. I had already tapped the one above the oil filter for my gage. 4an no restrictor either.
Old Nov 6, 2012 | 06:16 PM
blue0453's Avatar
-4 no restrictor.
