Oil in exhasust
Old Mar 17, 2008 | 10:51 AM
dhpro's Avatar
pull off the intake at the TB and see if there's any oil there...but a leak down test is the best way to tell. One of the by-products is higher IAT's, knock and reduced ponies as well. R/
Old Mar 17, 2008 | 10:52 AM
lpguy's Avatar
its only droplets when i fire it up
Old Mar 17, 2008 | 12:58 PM
BlackGMC's Avatar
Resident Retard
What type of PVC valve are you running and do you still have the vacuum hose that goes from the TB to the Passenger side valve cover hooked up? I think I read somewhere that you need a check valve in those two hoses....
Old Mar 17, 2008 | 02:19 PM
lpguy's Avatar
I have whatever comes stock on a 2006 Excuse my ignorance but does anyone have any pictures of the lines im looking for?
Old Mar 17, 2008 | 04:01 PM
TG02Z71's Avatar
So did you do any high speed runs before this started?? Was it over boosting? What is your fuel system set up like now?
The reason I ask is you may have already done engine damage if something was not right and you were hammering on it. Too many people here already know what I'm talking about. Blow by through your crankcase is a direct result of a broken ring land, washed out cylinder to ring seal.
I currently have this issue and have never had anything milky running out my exhaust. That milky stuff could be the oil from your feed line if there is enough moisture in the oil it will look like that.
If your truck runs take it out and run it for about a half hour, get it good and hot to burn off excess moisture, do an oil change and let your oil return line dump to a catch basin until about half a quart runs out the turbo, this will purge as much of the shitty oil from your system as possible.
Either way, moisture will continue to build up in the oil if you have a blow by issue.
Filtering or trying to catch this crud with catch cans will do nothing for you ultimately. If you have too much oil running to the turbo because your feed line is too big and you have so much moisture in your oil that it looks milky it may be too late.
Good luck.
Old Mar 17, 2008 | 04:29 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Milky oil in the exhaust is typically caused by the scavenging pump not returning the oil quick enough to the engine. The oil and condensation mix and come out the tail pipe, pretty common on low mount and rear mount setups if the pump fails, is weak or is clogged for some reason.
Old Mar 17, 2008 | 06:05 PM
lpguy's Avatar
The feed line size is -3. I havnt done any high speed runs... im babying it until everything is right... ill check everything out when i get home tonight...
Old Mar 17, 2008 | 06:37 PM
TrickTurbo's Avatar
Truck Sponsor
You can see the hose plugged in this picture, we then ran the valve cover to the air filter area with a small breather attached.
theres another pic here of the hose still being connected, yet to be vented.
http://www.nelsonperformance.com/gal...he/details.htm
Old Mar 17, 2008 | 09:42 PM
lpguy's Avatar
Ok have a small breather connected to the pcv line coming off motor and capped the tb as a 1st try... When i get home ill try and oil change and see what i get out of it... ill also double check the return line to make sure its not clogged If the -3 line is too big how do you guys use a nitrous jet to restrict it?
Old Mar 18, 2008 | 12:30 AM
kbracing96's Avatar
Is the pump running the right way? (wires switched) Did you check to see if it is pumping oil back to the motor?
