Oil in exhasust
Old Mar 16, 2008 | 05:50 PM
lpguy's Avatar
Default Oil in exhasust
Tried looking it up but can anyone tell me what to trouble shoot if i have oil in my exhaust? its in the tail pipe and the crossover pipe before the turbo...
Old Mar 16, 2008 | 05:57 PM
stock48's Avatar
9 Second Truck Club
Check out your oil return pump.
Old Mar 16, 2008 | 06:00 PM
lpguy's Avatar
The oil return pump is running
Old Mar 16, 2008 | 07:06 PM
bud8fan's Avatar
huh...thats not good if oil is coming from your motor before the turbo....
Old Mar 16, 2008 | 07:10 PM
stock48's Avatar
9 Second Truck Club
Have you got any blow by?
Old Mar 16, 2008 | 08:22 PM
TG02Z71's Avatar
you may need a restrictor in your feed line.
thunder550 can shed more light on this one. He's been through it.
Found this for you.
https://www.performancetrucks.net/fo...d.php?t=406970
Old Mar 17, 2008 | 06:57 AM
dhpro's Avatar
I had the same prob and it meant I had blow-by...in my case it was not roperly broken in, was running too rich and washed the rings...only a ring job if ur lucky...do a leak down test and ull know for sure...u see any oil leaks anywhere? Sometimes u end up with oil coming from the breather. I hope its not the case!
Old Mar 17, 2008 | 10:10 AM
lpguy's Avatar
K i tried searching but couldnt find any pictures... anyone have any pics of a oil separator/ catch can setup for a 2006 5.3?
Old Mar 17, 2008 | 10:24 AM
dhpro's Avatar
Catch cans are as much for vapour as actual fluid...but if u have oil in ur exhaust its more than a PCV issue. Are u just seeing smoke & fumes, or is there actual droplets? When I had my prob, I noticed it because a bike rack I was using actually got coated with oil. As for catch cans, try Mike Norris, RevXtreme (I just bot one of these), Elite Engineering...etc. R/
Old Mar 17, 2008 | 10:37 AM
lpguy's Avatar
i dont have any oil leaks anywhere else just a milky oil coming out of the exhaust
