oil drain place question
Old Sep 19, 2011 | 09:40 PM
Bad00silverado's Avatar
Default oil drain place question
Looking for a place to put the turbos drain. the kit is a pt88 front top mount. I really didnt wanna pull the pan off to put it there and have heard the front cover isnt the greatest. Has anyone tried to remove the oil sending unit and just put the return there? maybe a dumb question but seemed like an idea?
thanks!!
Old Sep 19, 2011 | 10:13 PM
Jake99's Avatar
Iv seen some put it on the timing chain cover, but that might be just as much work to pull??.
Old Sep 19, 2011 | 10:45 PM
orange1500hd's Avatar
are you 2wd? if you are pulling the pan is pretty easy, 4wd is a different story.
Old Sep 20, 2011 | 12:03 AM
02'Z71ONDUBZ''s Avatar
Wouldnt that be pressurized? Just put it in the front of the pan, its no problem at all on a 4wd.
Old Sep 20, 2011 | 12:31 AM
jasond26's Avatar
Are you talking about the oil level sender on the side of the pan? I installed my return there. So far no problems but I have not done a full pull yet.
Old Sep 20, 2011 | 01:36 AM
Is this above the oil level?
Old Sep 20, 2011 | 08:08 AM
Yes sir that's where I was talking about.
Old Sep 20, 2011 | 08:55 AM
custom 68's Avatar
to drill the pan or cover are you all just using just pipe thread fittings?
Old Sep 20, 2011 | 08:57 AM
Atomic's Avatar
I have a gauge for that
Dont use that, you need the drain to be above the oil level in the pan or it will back up to the turbo and blow through the seals.
Old Sep 22, 2011 | 03:02 AM
MoeDenali's Avatar
Valve cover.
