Oil cooled / turbo adapter
Truck Sponsor
We have had a few customers with oil cooled trucks. Needing to get oil to the turbo, and did not want to drill and tap or use a compression fitting. Both of those you have to take off the oil block and lines to clean out either the tapped shavings, or the tubing shavings.
So we build a few of these on a manual machine for prototypes etc, and will soon have these in stock.
You will simply unbolt the oil block, slide this in with another gasket, and some fresh bolts.
Part will be anodized black.
So we now will have both, standard billet blocks for none oil cooled trucks, or oil cooled.
This part is very thin keeping the stock oil block close to the block and not putting your lines in a bind.
You will have 2) 1/8 NPT ports for accessing the oil for your turbos etc.
prototype pics.
prototype pics.
Truck Sponsor
Drilling and tapping the pan is still needed. This part is for the PSI out to the turbo (s). Like was mentioned already.
thanks
There's a hole going from the rear port down to the outlet ports.
thanks
