Not making boost
Old Jul 18, 2013 | 08:45 AM
yzriders182's Avatar
Default Not making boost
Working on tuning the truck yesterday and its not making over 2.5-3psi boost. It's got a twin turbo setup with tial waistgates with gold springs in them (5.5psi ish). Any ideas on why it's not making boost?
Thanks for the help.
Old Jul 18, 2013 | 01:49 PM
Ferocity02's Avatar
Test for boost leaks? How do you have your wastegate lines plumbed? Boost controller?
Old Jul 18, 2013 | 07:19 PM
I have a cheap boost controller... Wastegates vacuume line is off of intake pipe just before throttle body...
Old Jul 18, 2013 | 07:48 PM
Chevy_King1500's Avatar
can you hear the waste gates opening? have you tried adjusting your boost controller
and what size are they?
Old Jul 20, 2013 | 12:40 PM
Their tial mv-s and no I don't hear them open. Disconnected the vacuume lines and same story. Pulled the line off the bov and it still blows off at 2-3 when I let up on it....
Old Jul 20, 2013 | 02:39 PM
smokeshow's Avatar
Mod with training wheels
Is your bov plugged into a manifold reference?
Old Jul 20, 2013 | 03:55 PM
mongooseboy000's Avatar
try running them with no reference. (nothing to waste gate) but be careful cause u might boost too much. one hit and thats it. if it builds boost then its a wastegat issue, if not then theres a boost leak. i had that on mine. ran it with no reference spooled to 16 psi, hooked it back up and followed the lines. ended up being a hole in the vacuum line. replaced it n good to go. also check charge pipe connections.
Old Jul 21, 2013 | 03:51 PM
Disconnected wastegate vacuume lines still 2-3 max. Pulled the vacuume line off the bov and it would still blow off... Shouldn't it stay closed? I think that's my problem or part of it right now.
It's a HKS bov
Old Jul 21, 2013 | 04:05 PM
yeah BOV should be closed when engine is off, at idle it may be slightly open
Gadgetized
Aug 21, 2020 03:14 PM
Silveradorst07
Dec 31, 2015 12:04 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
lxcoupe
Jul 21, 2015 02:12 AM
