no oil psi...WTF..
Old Apr 8, 2009 | 07:13 PM
05crew's Avatar
Default no oil psi...WTF..
well i just got back from the Dyno. and im on my 9th beer... the truck made 596rwhp and 659TQ. not to bad for 18* and 10.6 AFR and 13psi. so me and ryan took it for a drive...the truck pulled its *** off. as we were on the way back ryan gets in it a little and the oil psi is at 0.... so we pull off and shut the truck down. this is were the cursing began. the motor is not making no noise. it runs fine. so get it back to the shop and put a gauge on it at the turbo. still 0, rev it up and get it to 10 or so... so its not the sending unit.. could be the oil filter? or the pick up? or and i hope not the main barning.
any more ideas?
if its the motor than the 408 will come a little faster...like next week..LOL
Old Apr 8, 2009 | 08:14 PM
philntx's Avatar
What was the pressure while it was on the dyno?
Old Apr 8, 2009 | 08:35 PM
05crew's Avatar
around 40 or so...5mins latter 0
Old Apr 8, 2009 | 08:39 PM
sonoma43's Avatar
oil pump failure?
Old Apr 8, 2009 | 08:42 PM
05crew's Avatar
hahah. hope so....i dont know. the motor sounds like there is nothing wrong. even on 0psi
Old Apr 8, 2009 | 08:44 PM
sonoma43's Avatar
might wanna check out that oil pump. dont keep running the motor
Old Apr 8, 2009 | 08:50 PM
05crew's Avatar
yea..first the oil filter then drop the pan and cover and the pump.
Old Apr 8, 2009 | 09:20 PM
TrickTurbo's Avatar
Truck Sponsor
Pull the turbo pressure line aim into a oil safe container and start the truck for just a moment.
Oil pick up issue, pump issues or the oil filter. But the filter should have a bypass to allow oil to get around it, if its clogged..
Old Apr 8, 2009 | 09:26 PM
05crew's Avatar
i was hoping you would chime in rick....i am going to try and see tomm. i was thing it was that. we tee of the turbo supply line and no psi. so i think that it is a pick up or pump.
Old Apr 8, 2009 | 09:32 PM
quicksilverado's Avatar
Could be a partially spun bearing also. Mine did the same thing at the track last year. After a pass the oil dropped to 0 at idle. Above 1500 rpm it had just below 10 psi. Drove it home 120 miles. Found copper in the oil and swapped in the back up engine.
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
