No 3-bolt 90mm TBs around?
Old 03-23-2006, 05:44 PM
Vdrumright's Avatar
So there is a 3 bolt DBW TB available that will bolt up with minor modifications to a radix tube?
If so what is the cost and contact info?
Old 03-23-2006, 06:00 PM
F8L Z71's Avatar
I have an 01' GMC so my TB is cable driven and not the drive-by-wire thing the new trucks have.
The Nick Williams 90mm TB is 3/4 bolt meaning you can bolt it up to a 4bolt manifold or a 3-bolt standard if you elongate the bottom holes some. Then you just have to port teh J-Tube.
The other idea I had was the Starr 94mm TB bolts up to all standard GenIII intakes with a 3-bolt pattern. It would flow better than the 90mm setup but I'm told the power gain is negligible.
The NW 90mm is in teh $400 range. I just ordered mine from Thunder because I was tired of hunting and I order stuff from Tom when I can.
SS94S10
01-03-2019 01:57 PM
natejk
11-15-2016 08:05 AM
Wolftrk99
10-02-2015 08:17 AM
Chevy305
09-28-2015 09:21 PM
lycominghunter
26
09-25-2015 07:50 AM
Quick Reply: No 3-bolt 90mm TBs around?
