Newbe with a Procharged Silverado and some questions
Old Jun 12, 2010 | 02:06 AM
Blown06's Avatar
8 Second Truck Club
Wish I could help, but it looks to me like this issue is 4x4 specific. The p/s lines on my 2wd do not come up that high.
Probably have to do as others have suggested...........move the pcm.
Old Jun 12, 2010 | 08:37 AM
allballz57's Avatar
I would just move the pcm,thats what I did,and it is super easy!
Old Jun 12, 2010 | 08:45 AM
allballz57's Avatar
Heres a pic with the pcm moved out of the way.
You can tell I wasnt going under the frame with the plumbing,but it shows how much room there is without the pcm there! This pic was taken while I was mocking it up for a front mount design instead of underneath!
Attached Thumbnails Newbe with a Procharged Silverado and some questions-100_0125.jpg
Old Jun 12, 2010 | 09:39 AM
04SilverCrew's Avatar
I will take a look at moving it. Thanks for the advice. You know Procharger should add something to their manuals about the 4x4 models requiring this. Hopefully i can get that done this weekend. I have scheduled a tune for wednesday at Procharger in KC. I will post some numbers and pics from the day. Later.
Old Jun 12, 2010 | 12:56 PM
idahoblkss's Avatar
yeah i think if it 2wd you wouldn't have the problem, i made mine go to the out side of the frame though the top of the wheel well . if you get it just right the wheel wont rub.
Old Jun 12, 2010 | 02:49 PM
Most Hated's Avatar
mine s 2wd and my pcm had to be relocated when i use to have the pro
Old Jun 12, 2010 | 03:38 PM
So where is everyone moving their pcms to? Does it have to come out of the housing like the earlier pic w/ the race valve? Also, any tips or tricks you've found out during the process. Thanks.
Old Jun 12, 2010 | 07:24 PM
sureshot's Avatar
I just modified the ecu housing, but kept it so the ecu still clips in and out as needed. I made a little L-shaped bracket that attaches to the housing and gets bolted to the truck, using the same bolt that holds the bar running across the top of the battery. I basicly just moved it up!
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
D1SCSS
Jan 25, 2016 10:14 PM
mzoomora
Jan 3, 2016 07:06 AM
