New project. 2003 rcsb turbo.
Old Jul 24, 2016 | 10:33 AM
Merctech2's Avatar
Once I found the correct slip yoke I didn't have to shorten my drive shaft either. Wasn't too hard of a swap. Glad I did it even though it blew my budget for the turbo. I'm sure I'm not the only one that a 4l80 swap turned into a 6.0 swap also.
Old Jul 24, 2016 | 03:58 PM
2003RST's Avatar
Originally Posted by thunderwagen
I have a set of 60# injectors sitting around. If you are interested in them shoot me a PM.
OK I'll let u know if I need them.
Hey so I think my stock fuel pump just cropped out can I put my 320lph pump in and be ok? I have a return style fuel system with a stock fpr on the rail.
Old Jul 24, 2016 | 05:09 PM
A4edwin's Avatar
I bought a walbro gss340 for my turbo kit. And my fuel pump just died also. So I installed the walbro without any problems.
Old Jul 29, 2016 | 07:12 PM
2003RST's Avatar
The pump has two grounds. One is really light gauge. Where do I wire this to?
Old Jul 31, 2016 | 08:37 AM
A4edwin's Avatar
The gss340 is wired to the factory harness. Haven't had a problem with it yet. Only thing I don't like is having to cycle the key twice.
Old Aug 2, 2016 | 02:27 AM
Boost-freak's Avatar
change the unit
paint the hot side with heat resisting paint
change any clamp or v-band in the hot side
blow off valve and wastegate tial are awesome and cured my problem with on3 kit
cold side i didn't have any problem with it works great
injectures am running deatchwork 80 ls1 style with holly hi-ram
pumps i ordered them through a garage who did all the work
tranny if it's 4.8 it will take some beating but eventually will die so upgrade is a most
good luck
Old Oct 1, 2016 | 07:42 PM
2003RST's Avatar
Old Oct 1, 2016 | 08:48 PM
slvrram's Avatar
Originally Posted by NoorJ
but after doing it in a casual weekend I wish I hadn't put it off for so long
Isn't that the truth. I have 3 busted 4l60's laying in the shop that the 5.3 on N2O lay waste to before I wised up and did the 4l80.
OP... looks like you got it finished! Even managed to keep the coolant tank in the factory location. When test fitting mine, I couldn't see the oem tank fitting.
Did you go SD or hide a MAF somewhere? Any problems with the dump tube on the gate heating up the AC compressor? Seems my tube heads right for the compressor?
Old Oct 2, 2016 | 12:47 PM
2003RST's Avatar
The coolant tank is moved forward over the battery tray with new brackets I made. I haven't really seen anyone else go with this exact placement but I thought it fit well and I retained lots of factory lines with minimal trimming.
I was going to stay maf and try to use my k and n air box/maf set up but I put my overflow there lol. And I had to switch to SD anyways because my charge piping had the bung for the iat sensor so I ordered one from ballenger and used a 2bar map. I saw the issue the dump tube I haven't done anything with it yet because the truck isn't even running yet waiting for my tune. I'm a stainless steel tig welder so extending the pipe a Lil further won't be a challenge for me. But if it's heating Urs up looks like I'll have to do it. Not my daily so idk how much of a issue it's going to be for me. Thanks for the heads up
Old Oct 2, 2016 | 07:32 PM
slvrram's Avatar
That's a great idea. Never thought about that even. Most everyone seems to use a universal tank and mount it up near the firewall.
You're actually farther ahead than I am at this point. I ended up pulling the kit, putting the longtubes and N2O back on for the rest of the season to get a couple passes in before the track closes for the winter. The wastegate dump tube location just raised a red flag for me. I've got a short list small things like this I'd like to address when the kit goes back on.
