New project. 2003 rcsb turbo.
#21
You're actually farther ahead than I am at this point. I ended up pulling the kit, putting the longtubes and N2O back on for the rest of the season to get a couple passes in before the track closes for the winter. The wastegate dump tube location just raised a red flag for me. I've got a short list small things like this I'd like to address when the kit goes back on.
#25
I think it was a combination of both factors. I cut one I half and tried to bang it in and broke it. The aftermarket Dorman part seemed too big. Tired to buy a napa brand one to try something different and I got the part and it was another Dorman. I sanded it down a bit and got it in as much as I could got the bolt in the top. I haven't seen any leaks yet so I think it's ok.
#27
Its going on the dyno Monday. Fingers crossed everything is good to go and nothing breaks. I'm worried about the tranny only a couple thousand on the rebuild but 4l60's suck.
#28
that 80e shouldn't have a problem. What kind of driveshaft did you use? Skimmed through the thread didn't see what you're running. I'd be more worried about that if its stock.
Also what dipstick did you use? I used a hd. Had to make it fit with a trick manifold.
Just throwing this out there because it was mentioned. I had a stock length ( forgot that part) aluminum driveshaft made. Ran the stock yoke with a 60e with a fbody tailpiece and a stock rear end. Used the same driveshaft with 4" sonnax yoke with my 80e swap. Truck is a swb 2wd with 2" drop shackles and the middle leafs removed.
#29
He was talking about the oil dipstick. Granted that trans dipstick can put up a fight too until you fight the sweet spot or finally get smart and put it in while the trans goes in.
By the OP's last post, I think he's sticking with the 60e for a bit.
Just noticed you're in Deer Park zero2sixT... ever get out to Target in Kemah or the Home Depot off El Dorado?
#30
I thought he meant couple grand into an 80. Hope everything works out with the 60...
Had a much harder time with the trans dipstick vs. the oil.
I never been out to the Target. Didn't know about El Dorado.
Once I get this truck tuned, I might cruise by to see what's going on. Need that, finish up my catch can system, run my wideband/afr gauge and fp gauge. They hang out on week nights or just the weekend? What are the crowds like?
