new problem
Old May 25, 2015 | 04:04 PM
  #31
tim wellington's Avatar
Default map
change map sensor no more cut off
Old May 26, 2015 | 09:28 PM
  #32
Default 2 days
no more cut offs... damn ebay map sensor my advice stick to gm 2 bar 12580698
Old May 27, 2015 | 02:07 AM
  #33
1bad2k's Avatar
When the abs and brake lights come on, do they stay on or just go on/off randomly?
Old May 27, 2015 | 09:30 AM
  #34
Default abs/brake
randomly i clean the ground stay off for about a day.now it back. i just glad it not cutting off
Old May 27, 2015 | 09:38 AM
  #35
TXsilverado's Avatar
FYI, your ABS system does not work when both lights are on. stomp on the brake peddle to find out I need to do an EBCM repair on my 02 HD soon. I found a company on Ebay that does it for $50 with a lifetime warranty and a good reputation. need to clean my ground first to see if it fixes it, but of all the silverados ive had that all did the brake/abs light...the ground never fixes **** lol
Old May 27, 2015 | 09:41 AM
  #36
Y2KLimited's Avatar
Originally Posted by George C....
by any chance did you pinch the harness between the block and the trans when you did the trans swap
Thats exactly what I was thinking.
(Not that I ever will admit to doing that to my vette and having to redo the entire rear harness or anything, and eventually acquiring one and replacing it after putting 2-3 hours of labor into fixing it.)
Old May 27, 2015 | 07:28 PM
  #37
1bad2k's Avatar
I had a ground go bad on the front of the motor of my 96 c2500, it did the same thing. I cut it off and crimped on a new eyelet and it solved the prob. I wonder if your problem might be similar.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
