new problem
Old May 21, 2015 | 07:52 PM
  #21
08lambochevy's Avatar
Originally Posted by tim wellington
yeah i think when pull fused out to power wide band wire in back was loose .and on the ignition harness mine had jump a tooth. i noticed when i was replacing key cylinder .you suppose to turn til the on position and take small pin to release cylinder.mine wouldnt do that .mine released the start position i had take starter relay out turn mine to start and take cylinder out. 2 issues hope they fix it
Yea that was aggrevating as hell for weeks before finding out what it was, i hope that fixes it, as soon as i read about the door being open to start brought back bad memories of that suv haha
Old May 22, 2015 | 08:10 AM
  #22
tim wellington's Avatar
Default new problem
problem gone 1.5 hr of driving .50 stops no issues
Old May 22, 2015 | 02:53 PM
  #23
What was it?
Old May 23, 2015 | 02:47 PM
  #24
Default its backs
cut off dec 5mph or less .this time with code1635 any suggestion egr unplugged ,can map sensor send wrong voltage through code
Old May 23, 2015 | 09:19 PM
  #25
Default abs & brake light
does any body know if abs/brake light on this 5 volt circuit .the reason I asked is because I did scan log with my hp tuner changed pids to log voltage on tps and map .of course 1.5 hr of driving no cut off . but I also noticed my abs and brake did pop on like use to
Old May 24, 2015 | 10:33 PM
  #26
Default abs
yes on 5 volt circuit there was a service bulletin on2001 about redoing the ground cable ,mine was never upgraded ...upgraded mine no abs light and brake or stalls so far
Old May 25, 2015 | 07:05 AM
  #27
George C....'s Avatar
Formerly ScreamingL
by any chance did you pinch the harness between the block and the trans when you did the trans swap
Old May 25, 2015 | 08:30 AM
  #28
TXsilverado's Avatar
For abs/brake light, clean the ground at body mount in front of drivers door on frame. If that doesnt work, search ebcm repair on ebay.
Old May 25, 2015 | 10:56 AM
  #29
Formerly ScreamingL
whats abs?
Old May 25, 2015 | 11:09 AM
  #30
Originally Posted by George C....
whats abs?
I had some in college lol
