new problem
#21
yeah i think when pull fused out to power wide band wire in back was loose .and on the ignition harness mine had jump a tooth. i noticed when i was replacing key cylinder .you suppose to turn til the on position and take small pin to release cylinder.mine wouldnt do that .mine released the start position i had take starter relay out turn mine to start and take cylinder out. 2 issues hope they fix it
#25
does any body know if abs/brake light on this 5 volt circuit .the reason I asked is because I did scan log with my hp tuner changed pids to log voltage on tps and map .of course 1.5 hr of driving no cut off . but I also noticed my abs and brake did pop on like use to
#26
