New member seeking turbo advice
Old Feb 19, 2012 | 11:34 AM
jroctpb's Avatar
Default New member seeking turbo advice
Hey guy I have been lurking this site for a long time and found a ton of information, I think I am finally ready to do a rear mount turbo setup on my 2003 GMC Sierra 2500 6L my hp goals are not high I just wanna run a singel turbo at about 4 psi its my daily driver so I dont wanna go to crazy with the setup. I think I have everything figured out my only concern is fueling will the stock fuel setup be enough at 4psi? if not what will I need?
Thanks
Old Feb 19, 2012 | 03:40 PM
kbracing96's Avatar
No, your gonna need at least flex fuel injectors, 36lbs/hr or even better are the 8.1 marine injectors, 43lbs/hr. Cam, headers and tune can max stock 6L injectors. They are only 24lbs/hr.
Old Feb 19, 2012 | 06:20 PM
jroctpb's Avatar
thanks for the reply,Will the stock fuel pump be able to support bigger injectors or will I need a Boost-A-Pump as well?
Old Feb 19, 2012 | 08:31 PM
lglowe's Avatar
Walbro 255 is cheap enough and good insurance.
Old Feb 19, 2012 | 10:36 PM
05RST2NV's Avatar
Im looking at getting a Magnafuel 4303
Old Feb 20, 2012 | 04:42 AM
arctichc's Avatar
Registered User
Do you already have a turbo setup?
Old Feb 20, 2012 | 04:02 PM
arctichc's Avatar
Registered User
I have a intercooler/ radiator system that would drop right into your truck.The radiator is custom built and the intercooler was from a duramax diesel and was chopped down to fit along with electric fans. Fits like a glove and works great
Old Feb 20, 2012 | 07:36 PM
jroctpb's Avatar
Not yet the setup is in the works I am going to be doing a custom rear mount setup I already have all the charge piping intercooler, oil pump, and lines I was just concered about how to fuel it all, I think I will use Walbro 255 and 8.1 fuel injectors. Thanks for the help!
Old Feb 24, 2012 | 08:55 PM
wld1985's Avatar
I've got a set of those 8.1 injectors...Have'nt put them on yet,but they look pretty clean to me...
Old Feb 26, 2012 | 10:52 PM
jroctpb's Avatar
What size intake tube should I use? I was thing 2.5" from the turbo under the truck to the intercooler for quick response then 4" to the throttle body I am going to keep my MAF so it would be located on the tube from the intercooler to the throttle body aswell as the BOV. Will this work? any criticism is welcome I am in need of expertise.
