New magnuson for 2021
Old Sep 12, 2020 | 08:40 AM
03sierraslt's Avatar
Once Whipple brings the Gen 5 rotors over to the GM side there will be something interesting.
Old Sep 12, 2020 | 08:56 AM
terravast4's Avatar
Originally Posted by slow_lsx
I was waiting for the cathedral 2650, realized that it wasn't coming in the foreseeable future, so just bought some Frankenstein M311 heads and got the Hot Rod 2650 for the LS3/LSA.
what all did you need to do for the hotrod kit other than heads? Did you need to swap accessories?
Old Sep 12, 2020 | 01:00 PM
slow_lsx's Avatar
I'm on a truck accessories setup. I have a modified tvs 1900 tensioner bracket with the top cut off. I'm running an IW 8 rib kit, with an ATI 6% OD balancer. It sounds like a lot but it's not, it's super simple. Hubert (sleepergmc) has the same setup.
Old Sep 12, 2020 | 07:01 PM
terravast4's Avatar
I just want to clarify that the hot rod kit is a bolt on with only square port heads needed. Im running a hd tensioner and a IW 8 rib setup. How did you run the air intake?
Old Sep 12, 2020 | 07:17 PM
slow_lsx's Avatar
intake isn't on yet but will be similar to how I had it on my 2300 in the attached photo. the inlet on the 2650 is angled just a little different so might have to rotate it, or cut a piece off the current intake & angle it up to accommodate for the difference.
Old Sep 20, 2020 | 02:51 PM
xxch0dyxx's Avatar
Interesting topic. I'm going to keep pushing the 1900 for awhile, but a 2650 or larger would be nice to upgrade when I pull the heads off for porting...
Can't use the power until I get real rear tires anyways
Old Sep 21, 2020 | 08:25 AM
slow_lsx's Avatar
The larger blowers are nice because you get a good bump in power while still maintaining an excellent level of efficiency.
terravast4
Apr 18, 2017 09:17 PM
tt460
Jun 15, 2009 09:14 PM
CHEVY6000VHO
Sep 1, 2007 05:24 PM
Injected1
Mar 24, 2006 11:21 PM
