needing more what to do???
Old Dec 25, 2007 | 06:23 PM
  #21
kbracing96's Avatar
You still got that STS? Throw it back on there and then you can have 10lbs more boost! I'd do it!
Old Dec 25, 2007 | 08:31 PM
  #22
bud8fan's Avatar
heat will be your factor with a smaller pulley...run 2 intercoolers like moregrip ran on his setup...
Old Dec 25, 2007 | 08:32 PM
  #23
05crew's Avatar
no the sts is no longer with us, blown chevy are you saying i will not see nothing out of a smaller pulley? i have 6psi on a 3.0 and looking at a 2.7 and some 100mm setup!
Old Dec 25, 2007 | 08:33 PM
  #24
05crew's Avatar
want the meth help out with the heat?
Old Dec 25, 2007 | 08:39 PM
  #25
bud8fan's Avatar
a little...i was running meth but thru a 1/4 mile the temp would be knocking at 145*'s door climbing fast...
Old Dec 25, 2007 | 08:40 PM
  #26
Last Call's Avatar
TOTM: January 2007
Meth will help for sure.. But I would probably not go smaller than a 2.8-2.9. If you are looking for more power, I would start looking at cams. Soon as you get into the 2.8 category, belt slip and high IAT's are a never ending battle/
Old Dec 25, 2007 | 08:45 PM
  #27
05crew's Avatar
my cam is a 228-232 on a 114, so like i said before should i keep it a 6psi and spray like a 125 shot? the motor was made for the boost and Nitrous!!!
Old Dec 25, 2007 | 08:51 PM
  #28
Last Call's Avatar
TOTM: January 2007
Yes, I would hit it with some nitrous.. Start with a smaller shot though and work your way up. With 500rwhp, you should me somewhere between low and mid 12's. With a 100 shot, I bet you can could see some 11.5's!
Do it, do it!! lol I dont have the ***** to spray my radix.\ with a little N20.
Old Dec 25, 2007 | 08:58 PM
  #29
05crew's Avatar
it makes 488rwhp on 6psi and with the converter locked up it makes 504 rwhp! with 18deg timing not sure what it will run. i was told low 13s! how much hp do you think a 100 shot will put down on the dyno on top of a blower?
Old Dec 25, 2007 | 09:33 PM
  #30
Breeze's Avatar
11 Second Truck Club
Do youreself a favor and start with the 50 shot there is a hand full of others on here runnin nitrous through there radixes and I dont believe anyone has had the ***** to spray more then a 75.
