Need your opinions
Old Mar 25, 2016 | 07:37 PM
fastjweb's Avatar
Default Need your opinions
So currently my truck has run a best of 11.02 at 121, with 70mm Master Power, 15 psi, 93 oct. My above pass was on 9.5 degrees. Mods in sig. Looking at meth kits, what do you prefer for these trucks? Also I want to run 10s before giving up on 70mm, which should have no problem doing with meth and added timing. Im thinking about trying a Turbonetics 78/75 turbo as my next turbo. Is this a bad decision or should this be just fine for my set up? Thanks for the good or bad answers lol. looking to run meth and bump timing up to 15-16 degrees.
Old Mar 27, 2016 | 02:08 AM
lxcoupe's Avatar
I don't have the knowledge to answer your question, but I'm curious would you use E85 if it was readily available or is your preference pump gas/ meth?
Old Mar 27, 2016 | 08:07 AM
Beatdown Z's Avatar
Laid Back
There's a lot of options for meth kits. Alky Control, Devils Own, AIS, etc.
My truck has a Devils Own and my brother's Chevelle has an AIS kit. Both work good. I believe Alky Control has the option for stainless lines if you're into that kind of thing.
Old Mar 27, 2016 | 08:21 AM
AlwaysOnKill's Avatar
Put some 104 or 110 in it , give it 3 degrees and get your 10. Then get a meth kit and larger turbo .
Old Mar 27, 2016 | 09:16 AM
George C....'s Avatar
Formerly ScreamingL
Alkycontrol and be done with it
Herring
Nov 24, 2016 10:22 AM
simman22
Apr 16, 2016 07:02 PM
fillpot
Mar 1, 2016 05:51 AM
renright83
Feb 29, 2016 08:09 PM
XBlackXCheavyX
Feb 25, 2016 09:52 PM
