Spark plug gap
Old Mar 25, 2016 | 01:31 PM
BlackGMC's Avatar
Resident Retard
Default Spark plug gap
So i am swapping to some 7s today, i am running about 14-15psi right now so i figured it was time.
So my question on setting the gap. Is a good rule of thumb to set it wide and work myself down? Meaning should i run the widest gap without blowout?
Old Mar 25, 2016 | 01:49 PM
George C....'s Avatar
Formerly ScreamingL
.028 is where id set it...
Old Mar 25, 2016 | 02:33 PM
walledition's Avatar
.028 here with 7´s but only on 10-11 psi and works great
Old Mar 25, 2016 | 02:36 PM
GMCtrk's Avatar
I personally keep the gap as wide as i can without blowout..028" up to 22 psi no problem. At 15 psi you could probably open it up even more
Old Mar 25, 2016 | 02:46 PM
Vortec350ss's Avatar
I had mine at .028 and blow out was horrible in a lot of conditions...
Are you all talking BR7 when you refer to 7 heat range plugs or other?
I know we talked about this in the past but maybe meth had something to do with my blow out issues as opposed to others running e85.
Old Mar 25, 2016 | 02:49 PM
BlackGMC's Avatar
Resident Retard
Yeah that is what i was wanting to know. Start out wide the decrease if it blows out
Old Mar 25, 2016 | 02:50 PM
BlackGMC's Avatar
Resident Retard
I have a set of BR7s and TR7ixs.
Old Mar 25, 2016 | 02:55 PM
Formerly ScreamingL
Br7ef
Blowout can occur if charge is too cold for fuel used...meth or e85 act similar...they require some heat in cylinders to properly ignite
Old Mar 25, 2016 | 03:22 PM
03sierraslt's Avatar
Stock heads and non protruded plugs also recess the plug a decent amount.
Old Mar 25, 2016 | 03:42 PM
BlackGMC's Avatar
Resident Retard
So what are the advantages of a non-projected plug.
