need some help finding a part
Old Aug 31, 2007 | 06:31 PM
TrickTurbo's Avatar
Truck Sponsor
Default need some help finding a part
I am trying to find a larger Downpipe to turbo flange. I want to go from the stardard 3" flange to a 3.5 flange. It has to come straight off the turbo. WE could build one but would that rather find them in bulk.
wanting to build a 3.5 downpipe to see dyno results.
Rick
Old Aug 31, 2007 | 06:36 PM
XLR8NSS's Avatar
Adkoonerstrator
Rick
I have seen these in the past, let try to find it again.
Old Aug 31, 2007 | 07:23 PM
Bill Reid's Avatar
Are you guys going to merge into a 4" diesel exhaust or custom build a 3.5" "catback"?
Bill
Old Aug 31, 2007 | 07:54 PM
Slowhawk's Avatar
LS1Tech Sponsor
If you want to see if there are gains just run the down pipe open first.Ussually the cat backs hurt power.
Due to volocity you could probly just step it up to a 3.5" about 1' after the turbo.So when the gasses are cooling(they expand)it will have less resistance from the bigger pipe.
Done this before with good results.
Old Aug 31, 2007 | 10:37 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
What size turbine Rick?
Old Aug 31, 2007 | 10:59 PM
bud8fan's Avatar
rick here are some adptors that go from 2.5" to 3" or 3" all the way to like 5":
http://www.heartthrobexhaust.com/adapters.html
Old Aug 31, 2007 | 11:03 PM
TrickTurbo's Avatar
Truck Sponsor
What we are looking to do is some testing on our INTRO and Street Stalker kit. The Size of the Turbine?, not sure, we looking for caliper measurement or trim style.
The O.D. surface of the housing right now is under 3 inches. What I think will happen is a faster spool rate due to a greater pressure drop across the turbine wheel.
And really will not know until we build one. 4' DP just is not going to happen, there is not enough room near the frame.
Don has a good idea for the testing. A simple 2 piece DP would allow me to swap quickly between the standard and this one. Take a standard transtion pc and go from 3 to the 3.5. Joint would be will with a foot of the turbo.
Old Aug 31, 2007 | 11:18 PM
fullthrottledan's Avatar
I got mine here
http://www.atpturbo.com/Merchant2/me..._Code=ATP-FLS2
the one shown is a 3-4", but when i called them they said they can do a 3-3.5" and it will obviously be cheaper with no v band. its very short so you have lots of room to work with. Made my 4" downpipe easy to make
Old Sep 1, 2007 | 12:56 AM
TURBHOE's Avatar
you could also check out that link i gave you and call them to see what they can do for you. they make a 3.5" down pipe for the ford 6.0.
Old Sep 1, 2007 | 11:03 AM
I AM A MOTHERF*CKER
I guess what I meant to ask is what kind of turbine coupler -- T3 4bolt, 5bolt? T4 vband?
A pic would help me
I like what you're planning with the stepped DP.
