Need to pin one more crank
Old 12-23-2007, 08:35 AM
old motorhead's Avatar
Default Need to pin one more crank
5.3 is coming out and 6.0 going in under my radix. Need to pin the crank. I still have the kit, just need a couple of dowell pins. I hate to have to buy a complete kit just to get the pins. Anyone sell just the pins? Is there anything special about the pin material? Thanks..
Old 12-23-2007, 09:14 AM
FormerVendor
leftcoast32's Avatar
You can use an old drill bit the correct size to make the pins out of.
Old 12-23-2007, 09:55 AM
terravast4's Avatar
Exaclty how do you pin the crank and how do you know if you need this done? I have never had any problems but then again I don't want any either.
Old 12-23-2007, 09:59 AM
I thought about cutting the shank off of an old bit but was concerned that the bit material might be too hard/brittle.
Old 12-23-2007, 10:06 AM
You need to do it. I didn't and ended up buying another crank pulley. Buy a kit and it's pretty simple. I got mine from Magnuson. You drill two holes that go between the crank pulley and the crank snout. Insert the pins, replace the bolt and washer and you're done. They have a thick washer that serves as a guide so it's hard to mess it up. Having a rt. angle drive drill also helps.
Old 12-23-2007, 10:07 AM
FormerVendor
I had to do this for my new Innovators West Crank Pulley (different size pins) as the pin kit used a 3/16" pin and I couldnt find one anywhere. It is the same hardness as the old keyways we used on the small and big blocks. I have a set of the pins here that I could send you but you wont have them very soon because of the holidays.
terravast4's Avatar
Does this keep the crank pulley from walking off?
Old 12-23-2007, 10:11 AM
what a rush!
moregrip's Avatar
if you have a PDB, use the pin kit, I wouldn't do it any other way
FormerVendor
It keeps the Crank Pulley from spinning on the Crank Shaft.
Old 12-23-2007, 10:39 AM
terravast4's Avatar
I guess this is my next purchase.
Quick Reply: Need to pin one more crank
