NEED OPINIONS....408/pt88 cam??
Old Dec 26, 2009 | 10:39 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Default NEED OPINIONS....408/pt88 cam??
ok i am ready to get this build going again...
all am lacking to have the motor finished is:
CAM
valve springs
head studs
head gaskets
for you that don't know it is a 2001 RCSB 408 (9.25:1), 4l80e, front mount pt88, and some meth
i will be running cleaned up #317 heads and a truck intake...(THIS WILL NOT BE A RACE ONLY TRUCK)
i would like to buy a cam next and need opinions on what one?!?!?
i would like it to be as chopy as possible while still being efficiant
can i get some help please!!
Old Dec 26, 2009 | 11:43 AM
OLD BULL's Avatar
234/232 598/595 115+1
I believe Parish8 ran this cam with the same setup you have. I'd say it's a proven combo.
Old Dec 26, 2009 | 11:51 AM
GMCtrk's Avatar
I like the Speed Inc TU1 myself.
Old Dec 26, 2009 | 11:55 AM
i am basing my build off his.. so if someone could help confirm this that would be awsome...
but i am still open for opinions
Old Dec 26, 2009 | 12:11 PM
tarinitup's Avatar
9 Second Truck Club
Just spend $25 and get one spec'd by Pat G.
Old Dec 26, 2009 | 12:18 PM
who is pat g?
stock48???
i talked to him a while back but i just started working on this truck again and can't remember everything
maybe he will chime in and i will buy one from him
Old Dec 26, 2009 | 03:07 PM
skeet's Avatar
IIRC parish's cam was a 230/236 595/601 115+2 not a 234/232 598/595 115+1 also i think quik bought parish's cam and now runs it in his 4.8, IIRC quik ran the cam grind numbers off the cam after he got it from parish and came out to be 230/236/595/601 115 +2
just clarifing things alittle
Old Dec 26, 2009 | 06:59 PM
LsxCody's Avatar
i wouldnt run that in a 408
the cam spec'd out above would be a solid cam for your setup
Old Dec 26, 2009 | 07:02 PM
GMCtrk's Avatar
Why not? Parish said in retrospect that the 234/232 is probably too big
Old Dec 26, 2009 | 07:27 PM
LsxCody's Avatar
well i shouldnt have said not in a 408, im sure it would be a decent cam, i know a few ppl that have run it.
OP said he wanted some chop in his setup, i doubt with that cam being small in a 408 that it would hit any, on the other hand that 234 cam is bigger would hit more on the right lsa, i know lsa has alot to do with the lope but the duration plays a factor as well
