Need more power (pulley?sdtune?
Old Aug 19, 2009 | 12:37 AM
orangefun's Avatar
11 Second Club
Default Need more power (pulley?sdtune?
alright guys i am running a 5.3 in a older vehicle with a whipple. has a cam good full exhaust, tune, meth etc. here is the thing....i need more. thinking of a 75 shot, but with that i might have to do a SD tune, i will have to check with the tuner to see if the maf is maxed or close to being maxed, seconed question whipple sold me the smallest pulley for my set up (with staying on a single belt set up) they said it was rated at 11psi, but it only make 7.5-8.5 i have heard of going to a larger crank pulley???
guys I need some input...help me out
Old Aug 19, 2009 | 02:37 AM
MikeGyver's Avatar
Until somebody replies to tell you that a 5.3 with a single-belt Whipple should have more boost, I will tell you that a one-inch larger crank pulley is similar to a 3/8" smaller blower pulley. Whipple says that 1/8" = 1 psi. That is a lot of money to spend to get you to where they say it should be, but if everybody else says that 8-1/2 psi is good, then maybe a pulley is worth the price.
Old Aug 19, 2009 | 09:50 AM
orangefun's Avatar
11 Second Club
Where can you even buy the pulley???
Old Aug 19, 2009 | 09:57 AM
orangefun's Avatar
11 Second Club
Could the air blow off be weak and opening underboost eventhough i have it wirered to be shut????anyone have experiance here
Old Aug 19, 2009 | 02:33 PM
MikeGyver's Avatar
I think Whipple had the pulley made for me. The wires need to be removed from the bypass, and one of the lines open to the atmosphere. That way, it bypasses until you step on it. Here is a photo I got from this forum:
Old Aug 20, 2009 | 05:54 PM
orangefun's Avatar
11 Second Club
talked to the tuner......just going to throw a 75 dry shot on it.
Old Aug 20, 2009 | 06:06 PM
SincalT/A's Avatar
What size blower pulley do you have?
Old Aug 21, 2009 | 01:21 AM
orangefun's Avatar
11 Second Club
thats a good question, whipple told me it was the smallest one they make for the sigle belt set up.....the truck is in paint shop now, be a week before i can get the old tape measure
Old Aug 21, 2009 | 08:23 AM
tommy1005's Avatar
I would stay away from a dry shot on any vehicle....especially on a supercharged one. Going wet isn't that much more expensive and is safer when the boost kicks in.
thunder550
Oct 8, 2015 04:53 PM
JCW
Sep 22, 2015 03:59 PM
chevysten
Aug 13, 2015 07:36 PM
Ls3silverado
Jul 31, 2015 04:22 PM
