Need a little help turbo guys..
Old Aug 5, 2015 | 09:24 AM
Jake99's Avatar
Taller gear should spool faster if anything, rpm flashes to 3k or so off idle, its a home made log manifold with a 2.5 cross over from behind the engine, similar to what the kb racing kit is. I don't have any pic's of it. It's not great but not really to bad either, nothing that would lead me to think it wasn't flowing enough. Tune is set low 11s in pretty much all areas of boost. on the cam, I know it's not great, but iv had a 5.3 before with that cam and turbo combo and it spooled fast, something just seems way off hear.
Old Aug 5, 2015 | 09:26 AM
Jake99's Avatar
Also the exhaust has a 45 a foot off the turbo then right behind the front tire it has a cutout.
Atomic's Avatar
I have a gauge for that
Does the compressor spin freely by hand?
Old Aug 5, 2015 | 09:30 AM
Jake99's Avatar
Another thing, normally if you get one it at a higher rpm like 5k or so in second gear, then you nail it you normally have nearly instant boost, this think still rolls in slow up there, won't hit full boost till it gets third.
Old Aug 5, 2015 | 09:33 AM
Jake99's Avatar
Yes it does, spins free and doesn't show any sings of wear, if it was starving for oil I'd think the turbo would not live long, but it still feels tight as new.
Old Aug 5, 2015 | 09:36 AM
George C....'s Avatar
Formerly ScreamingL
taller gear doesnt actually help the combo
if homemade, what did you use to make the holes for the primaries?
on the crossover are you using a flex?
Old Aug 5, 2015 | 09:57 AM
smokeshow's Avatar
Mod with training wheels
3.08 would help spool vs RPM, but not vs time....and time is where it matters. Something does seem mechanically wrong. I'd richen up the mixture proportional to how much boost you're running...so lean it out down low. That'll help torque once it starts spooling up. It's not going to fix a mechanical problem if there is one though.
Old Aug 5, 2015 | 03:20 PM
Jake99's Avatar
Yeah, its only on a 26in tire so it really isn't geared that tall considering its only a 3600lb truck. My guess is cam timing, it seems to run fine, no excessive blow-by or anything. Just trying to see if there's anything I could be missing or try before getting into the engine.
Old Aug 8, 2015 | 07:56 AM
NoorJ's Avatar
how new is the setup? could the flex in the crossover be collapsed already?
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
GMCtrk
Jan 27, 2016 06:47 PM
jtphelps289
Sep 11, 2015 06:37 PM
06murder
Sep 4, 2015 03:54 PM
