Need info on FMU and the blow off valve PLEASE
Old Jun 13, 2008 | 06:26 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Need info on FMU and the blow off valve PLEASE
Guys I am in the middle of doing this procharger install.
?1 I do not need to run the FMU or the lines for it if I am uping my fuel pump and injectors correct??? Just want to be 100% on this.
?2 The blow off with this kit is made to blow off back into the intake side.. Can I use this blow off to vent into the air?? or do I need one that is for that specifically.
?3 Also where is the best place to mount the boost line to get the best reading??
I am trying to do the install as clean as possible, am not up to specs on FI on new stuff, as this will be my first FI NBS vehicle...
ANY HELP IS GREAT BIG HELP AT THIS POINT..
Thanks John
Old Jun 13, 2008 | 06:31 PM
02BlueStepside's Avatar
As long as you are tunning, bigger injectors, and bigger pump, the fmu and lines do not need to be run.
You can use the bypass as a blow off like you said, it will just vent to the atmosphere instead of back into the intake pipe
My boost line is off the manifold. If you look on the passenger side, there is a nipple new the back/top where you will have to pop off the plastic, then you will connect the boost gauge line to it. Do a quick search and you should be able to come up with a picture for this
I am running mine the same way it sounds like you want to and have no problems.
Old Jun 13, 2008 | 06:34 PM
Baltimore Whore
Hey thanks. Another ? is, I can actually blow air threw the blow off when it is closed, don't think thats posed to be...Also If I buy one I can run pretty much any brand correct???
Thanks again
John
Old Jun 13, 2008 | 06:38 PM
When its closed, air shouldn't go through it, it should go to the engine. When you let off the throttle and it opens, then the air should come through. And I would assume any bypass valve would work fine as a replacement, but don't know 100%
Old Jun 13, 2008 | 06:42 PM
2005 Silverado's Avatar
SPAM HUNTER
A kid i knew back in colorado had his D1 kits vented to atmosphere, he made him home made used a choke of a holly carb then it was just open with vacuum, also your going to really like it open to atmosphere, sounds bad *** when you let off, and if you route it right it will blow dirt underneath for a nice hollywood affect ill see if i can get a hold of him to see how he built it!
Dustin
Old Jun 13, 2008 | 06:45 PM
Baltimore Whore
Sweet, yah I def want a atmo blow off if I am going threw this to put it on. I think that the one with the kit might be bad, but i want to get a loud one.. Thanks keep it coming
John
Old Jun 16, 2008 | 08:20 PM
Baltimore Whore
Ok so I can use a turbo blow off for this correct?? It doesn't no what its on..
John
Old Jun 16, 2008 | 08:29 PM
sharpshooter's Avatar
I bought the new style procharger bypass.What do have the little grey one?You need a bypass valve not a BOV.
Old Jun 16, 2008 | 08:42 PM
Baltimore Whore
The are essentially the same thing. I am venting into the atmosphere..
John
Old Jun 16, 2008 | 08:54 PM
Are BOV's vacuum accuated?
