Need help with turbo setup
Hey guys I need help with setting up a turbo system on a 98 dodge ram. From what i've been told the dodge trucks are "non-tuneable" is this true and if so what fuel management system should i go with? I need all the help i can get with this one.. The motor is a fully built 3.9l V-6 eagle H-beam rods speed pro forged pistons, cam is114 lsa 222,228@ .050 & .520, .544 lift with the 1.6 rockers, heads are mild p&p with a 3 angle valve job and Stainless Steel valves.. 9:1 comp.. Any Help would be awesome..
IF the trucks fuel system will not pull fuel away for an MFG. protection set up, we can supply you with a stand alone upgrade that will allow you add extra fuel to the system, and you tune those extra injectors for the extra fuel needed. Timing is another problem you will be faced with.
If you are looking for a complete fuel and ignition systems I would recommend you look into FJO. Their systems controll spark, fuel, boost controllers, water meth, you name it if it has to do the engine their system can controll it.
I've been kinda looking at the fast fuel system..The whole stand alone system thing is new to me, I dont know very much about it at all.. Thank you for the reply I will look into the setup you mentioned..
With a dodge pretty much your only option to go stand alone. I have a friend with an 02 ram with a 4.7 and he is having hell trying to get his tuning sorted out, and is now going with stand alone. Once you get past a certain point with them you cant tune for it. Dodge needs to get over themselves and make their computers more friendly for the aftermarket.
I wish that dodge would do something.. the only kind of tune that i can seem to find is a falsh for the mods that i have, and even with just a flast all they can tell me is that they can get it kinda close. does anyone have a stand alone fuel management system for sale Im starting to run low on funds.. Any help will be a major help.. Im having H*ll with this thing.. Please help
you are going to need a system that does standalone fuel and timing. Get ahold of Nick at airram.com and talk to him he is going through the same issues you are going thruogh. He will be able to give you more sound advise on what setups are going to be better for the dodge than i can.
If your a budget minded and willing to do a lot of reading and learning, checkout mega squirt. I messed with it a little and it does a hell of a lot for what it is. This will get you started http://www.megasquirt.info/
Originally Posted by kenihemi
On the hemi trucks, we use the perfect power smt-6 piggy back for tuning fuel and timing for the turbos, along with a 2 bar map sensor and larger injectors.
iregret
Jul 27, 2015 10:32 PM
oharajo
Jul 18, 2015 09:24 PM
