Need help with oil line
I just got a turbo kit off here and need help with the oil lines I have no clue were it feed line hooks up or how the return line taps the oil pan
Do a search, its been beat to death... Put a -10a/n fitting in the front of the oil pan for the drain and drill/tap the feed block right above the oil filter for a -4a/n fitting for your feed.
there you go for your feed, would prob be cheaper to buy that than the cost of 1/8npt tap and bit. Good luck on the 1/2npt stuff for the pan, the only local place I could find that big of a tap and corresponding drill bit was at NAPA and they broke it off in me for like $60 bucks. Be especially careful to look up the right size drill bit for the 1/2npt tap as that is crucial. Mine is at home or I would go look at the size for you.
GXPJAY
02-13-2022 08:15 AM
GXPJAY
01-27-2016 11:45 AM
jroctpb
08-11-2015 03:52 PM
