need help with cam
ok so im selling my procharger either going turbo or juice.. not sure yet... either way what is the 2 best cams for each of these setups , and i want something you can hear.. dont like my current cam cant even tell its in..
ill find out what the specs of the cam i have now is ... i have no clue about cams, so when i had mine installed i let the shop pick it out.. just doesnt even sound like i have a cam.. whats the fun in that?
with FI you kind of have to have a trade off if you will...for best results you need a wide, or wider LSA than if you ran it N/A so your probably not gonna have that choppy idle
I dont think its worth running a tight LSA just for sound...
not a good idea...you will be bleeding boost out the exhaust seeing the intake and exhaust valves are gonna be open at the same time longer than if you had a cam like you have now with a 115 LSA...it will still work but not very well, it will be very peaky...
I disagree with you. Check out this cam from EPP lots of lope and a "blower cam" that makes great power http://www.exoticperformanceplus.com....html?item=679 click the you tube link in the description for a idle vid . You can make tons of power with tight lsa and lots of overlap with a centri blower. If this were a turbo no it would not be ideal at all.
This TBSS I help build and picked the cam is stock heads and bottom end with 112lsa and 11 degrees of overlap cam and is the fastest AWD TBSS @ 11.52 AT 120MPH on 10psi with a D1SC and has a great lope.
IDLE VID http://www.youtube.com/watch?v=3dGVFtBGOm8
1/4 mile VID http://www.youtube.com/watch?v=k7LKrAHW9PQ
