my turbo kit pics
Old Mar 16, 2007 | 10:27 PM
Default my turbo kit pics
Just figured i'd throw up a pic or 2 of my turbo kit.
it made well over 600/600 in second gear on a dynojet. Having some issues right now with what i think is a vacuum leak but should be back up and running soon.
Old Mar 16, 2007 | 10:48 PM
Last Call's Avatar
TOTM: January 2007
Looks good!
600hp is nothing to sneeze at... Track times soon??
Old Mar 16, 2007 | 10:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sweet, good looking setup!
Old Mar 16, 2007 | 11:01 PM
TurboGibbs's Avatar
Very cool It's about time!
Old Mar 17, 2007 | 01:04 AM
thunderwagen's Avatar
Looks good bro.
Old Mar 17, 2007 | 01:54 AM
365ZUM's Avatar
Keep it!
Old Mar 17, 2007 | 08:50 AM
TieRod's Avatar
I was starting to wander if something happen to you. LOL Nice #'s
Old Mar 17, 2007 | 09:29 AM
yeah, i got it trailered from Turbozone to Dez just after Christmas. It was a mess. Vacuum leaks, exhaust leaks, burt wires, wrong plug wires, intercooler full of water, problem after problem, after problem. So, nearly $6000 later I picked it up from Dez on Feb 2. They worked their ***** off on it and thought they had found all the problems. It was a ******* Beast.............for about 30min, lol. It went into limp mode on my way home. UGH. A few weeks later it was hauled back down there.
Turns out there was a problem with the alternator and the pcm. I went down and picked it up 2 weeks ago. It was tune on 6lbs boost at that point. It felt pretty much like it did with the whipple on 10lbs boost. When i got home i turned the boost back up to 10lbs. Again, it was a friggin beast.............for about 15min, lol. Now it sputterrs, stalls, boggs, total lack of power.
We thought it was the spark plugs. I changed the pass side plugs in like 15min, no problem. The driver's side is a different story. I had to remove the turbo and crossover pipe to get to them. Wasn't all that hard once i figured it out. Problem is, i broke 2 vband clamps while re-assembling it. Over torqued them. oops. Anyway, the plugs were all fine. Pretty sure it's a vacuum leak. Not i need to find it. GREAT!!!!!
Pretty sure i'm dropping it off at a local garage for a vacuum leak test today. if that turns up nothing, i'm gonna have them do a compression test to make sure i don't have a f'd up valve or whatever.
I'll keep you all posted.
Old Mar 17, 2007 | 09:45 AM
BigTex's Avatar
Wow. I really hope you find the problem quickly and its a cheap fix.
Old Mar 17, 2007 | 11:01 AM
me too. the new vband clamp should be here any minute. gonna put the **** back together, fire it up, and drop it off at the local garage where they can check for vacuum leaks.
