my Truck&turbo kit, what do you think ?...
Old Aug 12, 2008 | 09:58 PM
  #21
chevrolade's Avatar
Badazz Truck,custom Fabbed Hood???
Old Aug 12, 2008 | 11:09 PM
  #22
mike06tork's Avatar
yes X2 what chevrolade said , its custom made, I wanted sumthing diffrent than everybody else so i made sum changes to the hood including the front bumper if you didnt notice check it out.
Old Aug 13, 2008 | 04:23 AM
  #23
Spoolin's Avatar
GFYS and STFU
How does the Hot side piping react when it get's really hot. I would imagine with the different metals and their expansion and contraction properties that they might put some stress on the welds no? Nice work!
Old Aug 13, 2008 | 02:07 PM
  #24
mike06tork's Avatar
Well as of right now i havent had a problem with the manifold welded to steel pipe. The pipe welded to the manifold is 1/8th thick. And the pipe welded to the T4 turbo flange is almost less than 1/4 thick. I think i shouldnt have any problem with this in the future it seems to hold on pretty good together, here is closer pic of my manifold welded together.
Old Aug 13, 2008 | 11:16 PM
  #25
IMD's Avatar
IMD
Banned
uhhh wtf manifold?
Old Aug 14, 2008 | 12:52 AM
  #26
mike06tork's Avatar
well hey guys since i removed my old 5.3l N/A cam wich i still had on. And i recently removed it and so now i want to buy a bigger cam. Wich cam would be better for my turbocharged set-up between this two cams?
cam #1: Specs: Part#54-000-11
Ls1 3726R/3728R HR114+4
Cams Specs – INT Exh
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
cam #2: used custom grind cam
236 / 242 on a 114lsa
gross valve lift... intake.616...exhaust.612
Old Aug 14, 2008 | 06:16 PM
  #27
IMD's Avatar
IMD
Banned
the one you had before. and maybe some punctuation while you're at it.
Old Aug 15, 2008 | 12:14 AM
  #28
mike06tork's Avatar
WTF... you dont even know what cam i had before and so what, you still understand it right. oohh well... happy now.
Old Aug 15, 2008 | 12:29 AM
  #29
stock48's Avatar
9 Second Truck Club
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
Nice turbo kit, I don't see a thing wrong with it. I would run a cam with 220* or less, Both those cams are too big for my taste.
Old Aug 15, 2008 | 12:45 AM
  #30
mike06tork's Avatar
stock48, you think this cams are to big for my 370ci. forged motor. I was thinking they were about the pretty good size for this engine, i dont know but i always liked cams with high lifts on them. But thats just me. well its hard to deside on wich cam i should go with, between this two cams.
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
