my Truck&turbo kit, what do you think ?...
#22
#23
GFYS and STFU
How does the Hot side piping react when it get's really hot. I would imagine with the different metals and their expansion and contraction properties that they might put some stress on the welds no? Nice work!
#24
Well as of right now i havent had a problem with the manifold welded to steel pipe. The pipe welded to the manifold is 1/8th thick. And the pipe welded to the T4 turbo flange is almost less than 1/4 thick. I think i shouldnt have any problem with this in the future it seems to hold on pretty good together, here is closer pic of my manifold welded together.
#26
well hey guys since i removed my old 5.3l N/A cam wich i still had on. And i recently removed it and so now i want to buy a bigger cam. Wich cam would be better for my turbocharged set-up between this two cams?
cam #1: Specs: Part#54-000-11
Ls1 3726R/3728R HR114+4
Cams Specs – INT Exh
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
cam #2: used custom grind cam
236 / 242 on a 114lsa
gross valve lift... intake.616...exhaust.612
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
#28
#29
9 Second Truck Club
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
#30
stock48, you think this cams are to big for my 370ci. forged motor. I was thinking they were about the pretty good size for this engine, i dont know but i always liked cams with high lifts on them. But thats just me. well its hard to deside on wich cam i should go with, between this two cams.
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
Avg Dur 281 285
231/237 LSA 114
Valve Lift 595-598
