my Truck&turbo kit, what do you think ?...
Old Aug 12, 2008 | 10:39 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Wow, that is really sweet!
Old Aug 12, 2008 | 11:21 AM
quicksilverado's Avatar
You are gonna need a much bigger filter than that if you want to run 15 psi. That tiny one will severely choke the engine.
Old Aug 12, 2008 | 11:22 AM
WJ MARK's Avatar
Looks good!, I forget what its called but you can weld steel to cast iron
Old Aug 12, 2008 | 11:29 AM
BlackGMC's Avatar
Resident Retard
Yep I have seen it done before but it takes a certain process to get it to hold up... I had a friend of the family weld up some cast manifolds years ago, but he was a master welder... He said something about preheating the cast then using a special type of rod or something like that...
Old Aug 12, 2008 | 11:33 AM
SLO TRUCK's Avatar
looks good, lets see some more pics
Old Aug 12, 2008 | 01:12 PM
MeanZ71's Avatar
Nice truck bro!
Old Aug 12, 2008 | 02:33 PM
mike06tork's Avatar
Well im using a holbart 210 mig/tig welder with shielding gas mixed with sum diffrent kind of gases so it can stick together, the two diffrent materials. It seems to hold on together pretty good ive done this before welding cast iron with steel in my old set-up like similar to TRICK'S front mount style log manifold, but i changed my manifold with this wich i like it better because its a much thicker material than the 16guage pipe i used before. And thanks for everything ill post more pic's of my set-up later on on so you can see it better.
Old Aug 12, 2008 | 05:54 PM
Turbocoop's Avatar
That looks really good, I cant wait to see it all together. What are you doing with your old leftover parts???
Old Aug 12, 2008 | 06:26 PM
mike06tork's Avatar
well here is my old style log manifold you can see at the bottom where i welded my stock manifold conector flange wich is cast iron welded to the steel material it holds pretty good. And i have a almost compleate left over kit here in laying around i might sell it cheap later on it would work prety good with my 5.3l.
Old Aug 12, 2008 | 09:39 PM
jow02327's Avatar
what hood is that and where did you get it? if you don't mind me asking, cuz i looks sick
