My truck is off to shop #4
Old Jan 25, 2008 | 06:38 PM
  #201
Allgonoshow's Avatar
bud, you are at w2w, put a rotrex on it....
http://www.w2wpowertrain.com/pc-122-...r-systems.aspx
Old Jan 25, 2008 | 06:43 PM
  #202
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by DanaliHD
because i'm stupid and misunderstood what they were telling me. they said they can't push it past 6lbs boost. translation: they dont want to push it past 6lbs boost because the backpressure is too high.
This is what happens when a pharmacist tries in talk about engines, lol. Probably similar to a mechanic talking about drugs. Everything gets all messed up.
I see.Surprised though. I know Mikes 408ci runs a T88 on a T4 flange and we push it without problems.I figured your's would work the same.
Old Jan 25, 2008 | 07:45 PM
  #203
i called Rick Head today (formerly of innovative). he said the backpressure has something to do with the wheel. no idea what that means but....
anywho, anyone know where i can get 8 rib pulleys for my engine? not the harmonic balancer but everything else.
Old Jan 25, 2008 | 07:46 PM
  #204
Casey2323's Avatar
ATI sells a kit...I think its around 1100.00
Old Jan 26, 2008 | 09:25 AM
  #205
8ALTNG's Avatar
Dan~ I think the name of the company is Innovative or something like that. MOREGRIP has one on his truck, pm him he will know.
Old Jan 26, 2008 | 09:44 AM
  #206
dhpro's Avatar
i think march makes a kit as well for about the same price...saw an add in Chev Hi Po for them I think. R/
Old Jan 26, 2008 | 07:43 PM
  #207
yup, innovative west makes the harmonic balancer or crank pulley or damper or whatever it's officially called. BUT, w2w thinks ATI will hook me up with one since i already have a superdamper on my truck. I'm in need of all the other pulleys and maybe some form of tensioner. i know sdce makes a 8 rib setup for the procharger. I'm waiting to hear back from them.
sure wish the truck had stayed with sdce instead of going to turbozone all that time ago, lol. i kick myself daily over that decision. wow. idiot.
Old Jan 26, 2008 | 07:51 PM
  #208
04Denali's Avatar
good luck, hope everything turns out for you. If anybody needs a break it is you.
Mark
Old Jan 26, 2008 | 09:12 PM
  #209
Bill Reid's Avatar
ATI's truck 8 rib balancer is 2% underdrive as compared to stock diameter... not really a big deal BUT going with an Innovators West Balancer (larger diameter) allows you to stay away from relatively small blower pulleys. At some point even 8 rib is inneffective when blower pulley diameter is reduced too much.
ATI has worked with grippy on the power steering pulley getting that done.
I would PM grippy on 8-rib
Put your current balancer up for sale in the classified's, IMO.
Bill
Old Jan 26, 2008 | 09:23 PM
  #210
moregrip's Avatar
what a rush!
you need something truck specific in the power steering pulley, i.e. larger ID than the car stuff. ATI makes that for our trucks. the other pulleys should fit just fine, however, if you do a search I have already test fit the pulleys you'll need to run, up to you.
And like Bill said, if you go with the IW crank damper/pulley you'll need a special bolt/spacer/washer combo.
