My new 408 D1sc combo
Old Aug 21, 2006 | 04:26 PM
Blown06's Avatar
8 Second Truck Club
Default My new 408 D1sc combo
Well, most of you know my 5.3 lasted like 2 days with the D1sc pushing 12+lbs. of boost. So now its time for a new motor. Here is the new combo. Any comments and recomendations are welcome. Not sure if this is going to be enough fuel system. I was talking to one of the techs at MTI and he said that they put big inline pumps on returnless fuel systems. All I have ever seen on this site is that is a no no. Are we missing something here?
Iron 408 using new 6.0 block from GM.
Eagle crank and rods
JE SRP or Weisco pistons. 9.5:1 CR
MTI Stage 2r ls-1 heads
Either MTI or Cam Motion custom grind cam
Intake ?
Long tubes with dual 3" exhaust
60lb. Injectors
Kenny Bell Boost a Pump
Meth kit
built 4l60e
yank 3200 converter
cal-track bar
and some kind of tires
What do you think?
Old Aug 21, 2006 | 04:51 PM
quicksilverado's Avatar
You may want to consider a 4l80e .
Old Aug 21, 2006 | 04:57 PM
gao8302's Avatar
That will be your weak point with that kind of power as my trans is my weak point now. But im looking a Flt4l65e. Either that or and 80e. My 60e isnt happy anymore and likes to slip.
Old Aug 21, 2006 | 06:24 PM
Dub Silverado's Avatar
Yea, you will be making way too much power for your tranny I think...
Old Aug 21, 2006 | 06:49 PM
ogkevin13's Avatar
Banned
same here go wit an 80
Old Aug 21, 2006 | 07:15 PM
Charged_5.3's Avatar
why 9:5:1 ratio? You should go lower.
Old Aug 21, 2006 | 07:23 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Since you seem to like to boost the out of your motor go with a lower CR 8.5:1 maybe.
What boost level do you plan to feed the 408? The same 4" pulley is going to make way less on a 408 vs. your 5.3
Old Aug 21, 2006 | 07:30 PM
ranwalk's Avatar
Personally I would stay with 9.5:1, the Procharger doesnt come on as early as a roots or twin screw. Need a little CR so you dont lose all of your low end.
Old Aug 21, 2006 | 07:43 PM
1SlowHoe's Avatar
Hmm, forgot it was centrifugal. Ok, nevermind what I said before.
Old Aug 21, 2006 | 07:54 PM
SCIV's Avatar
New rear end.
