Is my intake/maf placement messing with my start ups?
Old Apr 19, 2017 | 04:14 PM
trxmxzx's Avatar
13 Second Truck Club
Default Is my intake/maf placement messing with my start ups?
Just curious
I have a 90 mm throttlebody 4 inch intake then at maf tapers down to a 3 inch for the maf.
i've googled it and searched it and I'm not getting that question answered.
Whats the thoughts? My velocity might be off?
Truck is rough to start- when cold jumps rpm then falls on its face over and over - I have to hold throttle at 15-20% then 10 seconds later it's like a miracle Rpms run up quick then I left of throttle slowly
when end warm it sometimes catches and stays idling
then I started thinking my crank case venting- my pcv is to the back of the blower and my other valve cover is tied into my intake. So my crankcase is on a negative vacuum at all times!?! Any help to clear this up would be cool
Old Apr 19, 2017 | 04:45 PM
TXsilverado's Avatar
it shouldn't be an issue like that. has it done this since you originally built the intake tube?
Old Apr 19, 2017 | 04:48 PM
trxmxzx's Avatar
Ever since I put this mp122 blower on it- Nelson told me to check for vacuum leaks like 2 years ago.
It runs good but start up sucks ***
Old Apr 19, 2017 | 05:19 PM
did you check for vacuum leaks?
Old Apr 19, 2017 | 05:59 PM
trxmxzx's Avatar
lol sorry yes- that's why it's making me think of my crankcase venting
when I first got it going I couldn't pull the cap of the oil fill and when I did it would almost stall -
at that time I only had the pcv hooked up no valve cover vent (pluged)
Old Apr 19, 2017 | 06:05 PM
vent the crank case to atmosphere and see if it still does it.
Old Apr 19, 2017 | 07:11 PM
trxmxzx's Avatar
i think that I will- are you vented to atmosphere?
Old Apr 19, 2017 | 07:15 PM
My hotrod is through a catch can. The silverado is running a stock pcv setup
Old Apr 20, 2017 | 06:07 AM
trxmxzx's Avatar
Here's a clip that finally uploaded- this is just after it started so it's still a cold motor. I'm trying to upload the first one still
http://s15.photobucket.com/user/trxmxzx/media/Truck%20sierra%20and%20parts/D4EC7366-BE59-4BB6-B829-532CFE875962.mp4.html
Old Apr 21, 2017 | 07:59 AM
Gadgetized's Avatar
What are your fuel trims doing when it smooths out? When you first start an engine, the O2 sensors don't correct fueling until they have time to warm up.
