My catch can setup...
Old Jan 3, 2007 | 06:40 PM
  #71
Dbl G's Avatar
Correct again the Greedy is junk,,Air will and does follow the path of least resistance, look how close the holes are.
I ran a tube down into the bottom with some holes drilled into it for ventilation porpoises and it now resides in the Bimmer....
Old Jan 3, 2007 | 06:44 PM
  #72
Dbl G's Avatar
Originally Posted by moregrip
from what I've read(now) some sort of scrubber material is needed to seperate the oil and leave it in the catch can:
"The Greddy catch can, much like most catch cans on the market, isn't baffled. This means that oil filled gases flow into the catch can and right back out into your intake system. You need to add some sort of way to make the the gas condense so that the oil stays in the catch can. This can be done by stuffing the can with some stainless steel scouring pads or medium to coarse steel wool. I added a short piece of 3/8" pipe on the inside of the catch can on the outlet side going back to the intake so that the hot gases would be forced to flow through the baffling material"
Absolutely, the Medium should be Stainless Steel or something as such .
What ever used must hold up too the rigorous effects of heat , oil, moisture and cleaning chemicals used.
Old Jan 3, 2007 | 06:51 PM
  #73
moregrip's Avatar
what a rush!
an LS setup:
Old Jan 3, 2007 | 06:54 PM
  #74
moregrip's Avatar
what a rush!
another design:
Old Jan 3, 2007 | 06:56 PM
  #75
Dbl G's Avatar
A friend of mine on the West Coast is almost done running tests on a one way drainage valve. We are running some different set-up’s with varying boost levels.
Ranging from the stock 6lbs. of the F-150 H.D's,
Too where he and I are at 18lbs. here and he is hitting 21lbs.
Either the one way check valves are too strong or just the opposite.
Old Jan 3, 2007 | 06:58 PM
  #76
Dbl G's Avatar
another design:
The only drawback is if the oil is not drained away, it is drawn up via pressure. Like a straw in Chocolate milk (Kids blowing bubbles) The tube should be raised and or vented upwards to allow room for captured oil.
Old Jan 3, 2007 | 07:13 PM
  #77
Bill Reid's Avatar
an LS setup:
Yep, several ways to skin this cat. Bottom line, IMO, grippy is when desigining a system to best suit your individual needs that there never be positive crank case pressure. Dbl G brought up a great point earlier about larger fittings. I agree completely... and the way I will determine the elimination of positive crank case pressure will be adapting a vacuum/pressure gauge to the dip stick tube and going through normal and spirited driving conditions to see if its working properly or if improvments are needed. I know I said this before but my night shift schedule has me all jacked up on my days off and I don't feel like doing a damn thing ... lucky for me only one more week of night shift and then I get my life back!... back to day shift!
Bill
Old Jan 3, 2007 | 07:16 PM
  #78
Dbl G's Avatar
Guy's,,,,N.D. vs L.S.U.
Got's to go.....
Old Jan 3, 2007 | 07:21 PM
  #79
Bill Reid's Avatar
Played with this idea on gravity fed turbo drains into the oil pan... due to inefficiant/ineffective crank case evacuation (early learning curve days) pressurizing turbo seals and blowing oil out where it shouldn't go. Please keep us posted on your progress.
Bill
Old Jan 3, 2007 | 07:22 PM
  #80
Bill Reid's Avatar
Got's to go.....
What? No wireless laptop in front of the boob tube?
Bill
