My catch can setup...
Old Jan 11, 2007 | 09:08 PM
  #101
Dbl G's Avatar
The filter element is and will be the down fall too any product along these lines.
Old Jan 12, 2007 | 07:42 AM
  #102
TG02Z71's Avatar
Originally Posted by tirkob1
I think it would work fine, but returning the stuff to the engine would probably not be a good thing. There is usually some condensation and other crud (raw fuel vapors) in the mix that could contaminate your oil. Maybe just drain it to a holding vessel that can be emptied when needed.
Old Jan 12, 2007 | 07:57 AM
  #103
Dbl G's Avatar
A. The elements are no different the Home depot / Countless others everyone comes up with.
B. The horse has been beaten to death on many a Forum for many a motor.
C. This type of element clogs real fast, most are made of a material that cannot with stand the harshness of the petroleum based vapors.
D. If they are a fine metal they still clog.
E. There not deep enough and it will get sucked into the air path back into the engine.
F. You do not want them to drain back in there are contaminates suspended in the oil vapor that are harmful.
Find a drainable type with a filter membrane that can be cleaned with a heavy cleaner, oil under heat turns to a varnish based film, which over time will build up and harden rendering most elements useless....................
Old Jan 28, 2007 | 03:49 PM
  #104
Lord Aries's Avatar
I got my Catch Can installed last weekend that i got from Summit Racing...
So far it is working great... no more oil spiting out of the passanger sides Valve breather...
Sorry, no install pictures. my Digicam is broken. 8-(
Old Mar 13, 2007 | 09:57 AM
  #105
Dbl G's Avatar
Wink
Originally Posted by CHEVY6000VHO
PM me some prices on the polished one and the black one.
Have you designed them to have a bracket to fit our trucks yet?
Jim
If your running LS heads then yes....
FlyingLow
Nov 24, 2015 10:05 AM
nic351
Sep 24, 2015 09:43 AM
97_ek
Sep 23, 2015 09:16 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
silver-mod-o
18
Aug 25, 2015 08:18 AM
