Multiple questions about my setup, any input appreciated
if you are having return issues now you will have bigger return issues with E85
one of the last setups i did on E85 had -8 feed and -8 return, the past lightning we did has -10 feed and -8 return
for cocaine ill have -12 feed and -10 return
also most pumps dont like to be over 60 base to begin with so raising the pressure for the injectors to get larger will only skew the pumps output... Its preferred to run base fuel of 43 ish whenever possible on normal fuels
also look into max fuel pressure for injectors to handle, some dont like to be over 90
George, I was specifically waiting for your input.
My current fuel is E50. I'm going to just go to straight E85 for maybe a hair more safety margin on a stock engine.
I would lower the base to 3 bar, but as you already know my 1000cc injectors are small for E85. So 58 psi base is a compromise, but two 450s should be able to still flow a lot at 78 psi.
If I have to go to aftermarket lines I will use -10 for feed and return.....however of note, Fragola -10 lines are only .500" ID.
If you're running a pressure regulator, your pressure delta should be constant. So whether the pump pressure is 90psi or 45psi, the injectors will still see 58...assuming you set it to 58 with atmospheric pressure in the manifold.
havent looked into what the 450s are capable of but we just installed them on another lightning and we run base of 43 so we have room to go.... Most pumps dont like over 60 base.... Youll see them become unstable in drop fuel pressure and try to recover during the run
if you plan to then log fuel pressure during the pull to make sure youre safe, and make sure you log it for a 1320 pass as that much strain on the fuel pumps can show its ugly face fast compared to a dyno pull
IMHO your return should be -8 if using e85 just based on the volume of fuel you need to run and for it to bypassed
I've had major problems with fragola that have nearly made me go insane.
In fact I was just assembling a fitting yesterday and the damn thread stripped and I had to junk it. I had major problems with seepage (and some which actually would drip fuel) from the fittings as well that was blamed on me not tightening the fittings enough or putting oil on the flare.
The stock return line goes inside the fuel pump module and dumps at the bottom of the bucket.
#1 I finally got my fuel rails, lines and regulator up and running and preliminarily it looks like I may not able to return enough fuel to the tank through the stock return line (I let off gas pedal while driving, AFR goes into 12s). I haven't tried tuning yet to see if it's a tuning issue, but I will check that tomorrow or the day after. I was able to turn down the fuel pressure at idle to 58 psi (at 1 atm) without issue. With the intake line hooked up, it seems to idle around 48 psi. If I can control the pressure at idle does that mean the return line is adequately sized?
#2) My turbo is 75 mm compressor and 74 mm turbine. 1.0 AR T4 with 4" exhaust to bumper. Based on my time in sig and raceweight estimated of 5k, is this turbo enough to put me in the 10s on a good pass? How much potential HP is there if I hack off the exhaust and just run an open downpipe?
#3) I've previously ran my track passes on 315/60 drag radials, which are 29.5 tall installed. I need to get some 15" wheels in 6 lug, and I'm wondering if I would actually be faster with 28" tires if they can hook as well. Gears 4.11. When I crossed the traps last time at 125.9 my rpm was 6413. Some calculations show my converter is slipping a lot (like 25%) which I want to confirm and need to see what parameters to log on EFI live. I have the capability to lock the converter in 3rd gear and my trans is built to handle that if needed.
#4) Assuming good fuel delivery (I have 2 walbro 450 pumps going thru the stock 3/8 feed and filter and then into the rails and then into the external regulator), approximately how much power can my 1000cc injectors support on E85 with a base pressure of 4 bar? The flow rate is 114 lb/hr @ 4 bar.
114lb/hr@4bar at 95% IDC would support about 860rwhp (550L/hr). Dual 450s at 85psi flow about 587L/hr (this is 85-58=27psi of boost), so you should be good there. At that flow rate through a 3/8" line you will have about 2psi drop in the fuel line, so you are still fine. I dont know about the stock fuel filter, but even if you have a 5psi drop in pressure you are still fine to 20psi of boost.
his slip is more then 8%
a 30" tire with 410s and 6400 rpms will trap much higher then 126 mph in 1:1 ratio
he should only be around 5800 rpms if setup had no slip
he should be around 139 mph at 6400 rpms with his 410s and 30" tire factoring in zero slip
also unless your not maxing out the 4" exhaust then a cutout wont gain ya much, however if the 4' exhaust has alot of bends then it could gain ya some
i know on 12 psi i gained 10 rwhp opening cutouts on a dual 3" exhaust from when i had twins. the cutouts were right under the cab vs the exhaust exiting out in front of pass rear tire
Gonna make me do math arent ya?
So with a 1:1 trans gear, 4.11 rear gears, 6400 engine rpm, and 29.5" tire that is linear velocity of:
[(6400/4.11)*pi*29.5/(12*5280)*60]=136.66mph.
His real speed was 125.9mph
125.9/136.66=0.9212 then mulitply by 100 to put it in percent
That is 92.12% of ideal speed, so 100%-92.12% is 7.88% slip.
My downpipe was 5", so I wasnt expecting much with the fender exit, I mainly just wanted to be cool and loose the weight of all the exhaust. I was still suprised it made such a difference in spool time.
I'm trying to understand why there is such a discrepancy between your math (which looks legit) and the Wallace racing calculator (where I got the 25% number).
Also, if all I'll gain with shorter exhaust is spool time, then I'm okay currently. Spool is one thing this setup doesn't have a problem with.
